i convert a avi file to svcd using tmpgenc then i demultiplex it and use bbmpeg program after i finish i burn the files that were made from the avi with nero
but when i play it on my dvd player it will pause for a few seconds in some parts of the movie i have tryed this a few times and only 1 cd worked fine
im using a celeron 400mhz 256ram is it because of my processor
also takes 26 hours to convert to svcd
how can i speed the convertion time up
plz help... thanx =P
You can speed up conversion time by using the simple techniques mentioned in the conversion guide for converting to SVCD. (For example, make TMPGEnc high priority when active and turn off your screen saver...etc.) But the best way to speed up your encoding is to get a faster computer.
I just did an SVCD using my friends computer (top of the line: Athlon XP processor, 1.7 GHz, 512 Mb RAM, etc.) and it only took 5 hours.
But why do you demultiplex after you've done the converting? Do you have sync problems of some sort?
TV RIP is there something wrong?
By JackDanielZ in forum Video ConversionReplies: 3Last Post: 22nd Apr 2012, 12:35 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
what is wrong with this tape?
By thegreatbear in forum RestorationReplies: 2Last Post: 13th Mar 2008, 23:00 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
