This is so simple. I picked this up from another forum. After you set up a new ATIVCR profile in MMC 7.5 do this:
1. Capture in ati.vcr format.
2. Open the ATI Library.
3. Right click on the file and choose convert to Mpeg2. It takes only a couple of minutes!
In very preliminary testing I have found that the quality of capturing in ati.vcr format and then doing this conversion is outstanding! Much better than straight real time mpeg2 captures. But my findings are preliminary. Wanted to post this first and then continue testing.
Give it a try!
The ati vcr 1 and 2 codecs are an old non standard version of MJpeg compression. You probally be beter using PIc motion or a hardware mjpeg card.
Old codecs yes - but they seem to be optimized for the ATI hardware and I still think they are being tweaked. By using the "export to mpeg2" feature in the ATI Library my VCR2 captures convert quickly to mpeg2. There is no time consuming re-encoding involved.
I'm still playing around with it but the quality seems to be very good. If the VCR codec is in fact optimized for ATI hardware - as I assume it is - then captures in the ATI VCR format with a quick "export to mpeg2" using the ATI Library feature may provide a better real time capture as opposed to straight mpeg2 captures. Not sure because I have not had sufficient time to test.
I am curious as to why ATI still included the VCR codecs in MMC 7.5. Perhaps the codec does offer better quality than the mpeg2 codecs included. If that proves to be the case then the "export to mpeg2" feature may prove to be a nice feature for SVCD creations.
I have the Picvideo codecs installed but encoding post capture is required which can be time consuming.
<font size=-1>[ This Message was edited by: next on 2001-12-31 21:14:04 ]</font> -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Actually I think they may be some sort of non standard version of mpeg codecs not mjpeg compression. The reason I mention this is because the "export to mpeg2" feature does not re-encode the VCR captures. It may just be an offset or header non standard issue. Not sure at the moment though but i'll find out.
Convert ATI AIW .vcr format to anything?
By madmartian in forum Video ConversionReplies: 14Last Post: 4th Jan 2012, 06:59 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
How to Connect VCR to ATI 650
By jshapard in forum Capturing and VCRReplies: 0Last Post: 22nd Sep 2007, 11:18
