  1. I have a couple of clips I need to encode for Quicktime Mac. What's the highest quality I can go to and which software should I use? Thanks!!!
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    ffmpegX or MPEG Streamclip. On which device will you play them back?
  4. These files are intended ONLY to be played on Mac. Thanks!!!
    Okay. Then either app will do the job for you although ffmpegX may be tweaked for maximum quality. Keep the original pixel size. See this thread for more settings:
    https://forum.videohelp.com/viewtopic.php?t=290011
