I have a Lite-On 1633S burner and some Ritek DVD+R Dual Layer disks. I just used DVD Decrypter in ISO Write mode to burn a 7.7GB ISO image. The resulting disk is unreadable... when I put it in my DVD ROM drive, the drive just spins and spins. Any attempts to look at it result in a hung process.
What do I need to do to successfully burn a movie DVD on to a dual layer disk?
Results 1 to 13 of 13
I would try a Verbatim DL, they seem to have the best success rate. Did you try it in a standalone player, or just the computer?
I tried it in my DVD-RP56 just for giggles, and it played. The menus work, but when I play an episode (Firefly Disc 1), the video is full of pixellization and artifacts, and then freezes solid at 26 seconds. The first time it did this, I saw an H)5 error, and nearly had a heart attack. The tray wouldn't open, but hitting the power button did make the player shut off after a minute. Then I could power back on and get the tray open.
Can I try burning at a different speed, or is there some other button or feature that might make a better copy? I've always heard that the Ritek media was very good stuff. -
as redwudz suggested use VERBATIM DUAL LAYER MEDIA. RITEK's DL media isn't the best to use.
Trust me it's the media so use the Verbatim and you buy a ten pack of them here for $17 after rebate. http://www.newegg.com/Product/Product.asp?Item=N82E16817131163
Does your DVD Rom support dual layer media? Quite a few do not.
Does your DVD-RP56 support the format you burnt the Firefly episode in?
Those are probably the reason for the errors and non-seek problems you are experiencing. -
Try to burn it using ImgBurn instead of Decryptor and don't burn faster than 2.4X. I just did 2 discs today using that method as well as setting the drive to burn the discs as DVD-ROMs. They are flawless and work fine in all my players including my Panasonic DVD recorder which doesn't normally accept any +R product...
Oh yeah, I use Fuji +R DL for the burns... -
What do you mean by "format"? I just set Decrypter to use ISO Write and hit the go buttonOriginally Posted by ROF
OKOriginally Posted by oldfart13
What do you mean by "burn the discs as DVD-ROMs"? As opposed to RW? Is this a setting or ???I just did 2 discs today using that method as well as setting the drive to burn the discs as DVD-ROMs. -
He/she is referring to setting the book type to DVD-Rom. If your burner supports it, you can trick your DVD player into believing the DVD+R is a real DVD-ROM disc and not a DVD+R. Sometimes, it's the only way to get a DVD+R media type to work.Originally Posted by jnojr
As previous posters suggested, I would try better media. Ritek's media has really gone in the crapper these days.
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 06:30 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 13:53 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 19:08 -
trouble burning DVDs
By nick177th in forum DVD RippingReplies: 9Last Post: 5th Oct 2007, 17:10 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 21:37
