  1. Dear friends,
    Does you recommend any capture card that has hardware mpeg-2 encoder and pal-m/ntsc ?
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    The Hauppauge WinTV-PRV-250 is a good card as is the Hauppauge WinTV-PVR-350. Both are PCI capture cards that do hardware MPEG-1 and MPEG-2 capture. The difference is that the 350 model adds TV output which is fine tuned for MPEG output only.
    Another good choice is the Hauppauge WinTV-PVR-USB2 and the ADS Instant DVD 2.0 both of these are external USB 2.0 devices that do hardware MPEG-1 and MPEG-2 capture. The Hauppauge seems to have the same quality as the 250/350 PCI cards. The ADS Instant DVD 2.0 is in my opinion a tiny bit better in image quality but it has no RF tuner and the software that comes with it is not suited to setting up unattended recordings making it a poor choice for recording from TV whereas all the Hauppuage units excel at unattended TV recording set-up.
    - John "FulciLives" Coleman
  3. These cards accepts PAL-M, NTSC ?
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    We looked at PAL-M a few months ago. Hauppauge isn't clear about PAL-M support in the PVR series but some of the western hemisphere ATI All-In-Wonder cards are said by ATI to support NTSC and PAL-M. The european models DO NOT support PAL-M.
    https://forum.videohelp.com/viewtopic.php?t=286530
    http://www.kiva.org/about
    Apr 2005
    Rio Grande - Porto Alegre - RS - Brasil
    I have a Hauppauge PVR 500 MCE NTSC version and it works on PAL-M (I`m brazilian too). I asked Hauppauge before buying it.
  6. Caple
    I send to you a private mess.
    Please, answer it.
    Te mandei uma mensagem privada.
    Por favor responda.
    Obrigado
