I would like to know how to insert chapter points into preexisting divx, xvid files.
A chapter break about every 10 minutes.
Can Virtual dub do this?
Thanks!
http://www.divx.com/divx/create/
Chapter points for easy navigation when you combine multiple files. -
Well there is really no such thing as an XviD file, other than a raw XviD stream. The DivX media format as already covered supports chapters and can contain XviD. mkv, mp4, ogm and dsm also support chapters and can contain XviD.
Basically what it comes down to is that the container not the video codec determines whether chapters are possible.
DivXMux should be able to do chapters if you can write the xml input for them.
For mkv, ogm and mp4 are much easier since they support the ogm chapter format which is just a text file which you can easily create. Then again maybe there is a convesion util for .divx?
Should point out that the only current standalone support would be for mp4 and .divx.
Shifting Chapter Point on DVD without reauthoring
By Instant Martian in forum DVD RippingReplies: 4Last Post: 4th Sep 2009, 10:10 -
upscaling xvid and divx files
By doitnow in forum Newbie / General discussionsReplies: 15Last Post: 26th Mar 2009, 04:25 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Placing a chapter point at layer break spot?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 19:02 -
Automatic DVD Chapter Point Insertion
By cw4u in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2007, 00:43
