Hey I'm a newbie to the whole ISO things and I'm not sure what I did but I have an ISO file that I can't delete. I tried rebooting in safe mode and doing all sorts of things but it keeps saying that it is in use so it can't delete. I'm not exactly sure what program I used to make it, but I'm sure there is an easy way to get rid of it.
Thanks a ton
Tim
Have a read of this http://www.virtualdub.org/blog/pivot/entry.php?id=89#body it's about AVIs, but is the same problem you have with the ISO.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
You got sorted yet?
Try this little free prog, it does exactly what it says on the tin! It deletes files locked by your system.
http://www.download.com/3120-20_4-0.html?tag=srch&qt=moveonboot&tg=dl-20
Let's know, Good Luck.......James....hmmmm....nice..... -
You wouldn't happen to have the ISO image mounted to a virtual drive?
If so unmount the image. This is a common mistake people make. They'll mount the image in order to burn the contents of the ISO and then wonder why afterwards they are unable to delete it. -
hi another great little app for unlocking files is this. its freeware and works great
http://ccollomb.free.fr/unlocker/ -
if you signed in under safe mode the only other reason could be permissions. Was this created under a different login? login as admin and delete it. Also try to rename it , see if it takes it then you can reboot and delete it.
Originally Posted by sidewinder
delete it in a dos prompt after killing off the explorer.exe process. then just restart explorer process.
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
cannot delete vlc recorded file
By octeuron in forum Newbie / General discussionsReplies: 4Last Post: 29th May 2010, 05:00 -
How to delete ISO files?
By millyvanilly in forum Newbie / General discussionsReplies: 13Last Post: 26th Jan 2009, 15:00 -
Batch file that can delete a specific file
By Dark_Raven in forum ProgrammingReplies: 1Last Post: 10th Jun 2008, 08:16 -
Can't delete AVI file
By Fbee in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 21:25
