I want to make a KVCD by using as source file one .MPG file, captured by Cyberlink PowerProducer II, from a VHS tape in EP MODE. The video is MPEG-2 and the audio is LPCM.
I use TMPGEnc (new version), but as you all know you can't import a MPEG-2 file into the software, so I use VirtualDub MPEG-2 to frame-serve the video & audio streams into TMPGEnc.
But the problem is that when importing the .vdr file, TMPGEnc reports It will have to do Inverse Telecine. Now what does that mean?
So, I choose the right parameters for the KVCD, and now hit Start, and then in the lower part of the screen I see that TMPGEnc is doing that Telecine stuff and need to calculate (i don't know what), and after that it will start the encoding process.
Now, I didn't wanted to wait a lot of time, so I unchecked the option in "Settings" (the one which says 24fps something..), so I hit again the Start button but in the screen appears an error window, (i don't remember the text on it) because I was on another PC. IT also says something about a 'ntdll.dll' file.
So, what I'm asking is how to reencode a MPEG-2 file with LCPM audio, using TMPGEnc without doing that inverse telecine, and what does that term means?
I personally wouldn't use the KVCD format, but whatever works for you.Inverse Telecine
Inverse telecine (IVTC) is when a codec takes a 29.97 frames per second interlaced NTSC video that has gone through the telecine process and reconstructs the original 24 frames per second progressive FILM video.
Why LPCM audio? That takes up a lot of space that would be better used by increasing your video bitrate. If KVCD can use AC3, that would be more compact. You could convert it with ffmpeggui.
The rest I'll leave to someone else, I don't really do VCD formats.
EDIT: I don't think VCD can use AC3, but mpeg-1, layer II audio should work better than LPCM.
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 23:10 -
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 19:59 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Change bitrate of LPCM 5.1 ch ( audio file after demuxing )
By wisitch in forum AudioReplies: 3Last Post: 8th Apr 2010, 13:09 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 12:25
