Hi.
Re: Video Files and Jpeg Images On The Same Disc??
I want to put a homemade video on to blank media disc, and i also want to put some Jpeg Images on the same disc.
Is this possible?
If so how would i do this?
Thanks to all
please try post in correct forum. if you don't know where to post use the general forum. moving you.
yes, it's possible. but we need more information.
do you want dvd-video that works on most dvd players? or just a video on a dvd/cd???
what tools do you usually use to convert to dvd? -
I'm assuming your talking about a DVD. Simply create a folder and call it pics (or whatever) and use lower cased letters. Then burn it to the root along with your VIDEO_TS and AUDIO_TS folders. The dvd player will ignore the pics folder, but it can be accessed using a PC.
I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
do you want dvd-video that works on most dvd players? YES
what tools do you usually use to convert to dvd? NERO 7
Is there a easier, or better tool to use?
Thanks. -
Use Nero Burning Rom. Choose DVD Video Template. Drag your VIDEO_TS and AUDIO_TS in there. Put your images in the pics folder (or whatever you name it) and drag it in there also. Then burn it.
Anybody with a PC with a DVD-ROM will be able to get to the jpegs.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
I agreed. I compile my pictures into slide show with Memories on TV, and author with Video into a DVD.Originally Posted by MI6
Most of the time, my follks like the Slide show made by Memroies on Tv more than the video. ( Ha.. Good reason to rush out to buy a $$$ 3CCD DVcam. NOT.)
how to make BD Video disc using m2ts files
By vikas.babu in forum Authoring (Blu-ray)Replies: 6Last Post: 20th May 2010, 02:49 -
How to best deliver video files on disc?
By bobbt_tee in forum Video ConversionReplies: 9Last Post: 2nd Feb 2010, 10:26 -
VIDEO-TS.......how do i change format from disc to my video files
By COT51E in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2008, 12:32 -
Can I Put Video Files And Picture Files On Same Disc?
By Lennoxtown in forum Video ConversionReplies: 3Last Post: 29th Dec 2007, 07:05 -
Can't see DVD video files on disc, but it still plays
By skootles in forum DVD RippingReplies: 1Last Post: 25th May 2007, 20:05
