a) yes, I followed galactica's advice and did a forum search first .. but only found hints at win software.
b) the question: i have a 700 MB divx file, which i would love to burn to VCD .. toast tells me I need 1.02 GB space for that (uh?) .. well .. so i guess easiest would be to cut the 700 MB divs into 2 parts of 350 ... is there any way of doing that fairly easy with re-rendering, decrompressing / recompressing?
Thanks a bunch
Wow .,. THANKS ... explicit seems to be doing EXACTLY what I wanted to do .. and it is SO easy to use .. it even sets the middle point itself and all i had to do was click OK and after a very short while i had 2 files apply called part 1 and part 2 ... thanks ... i love this forum!
Would be nice to have a visual aid to deciding where to make the cut (other than QT or D-Vision) while still having exact time code. QT shows time, but won't save without reencoding. D-Vision doesn't show exact time, and in my experience, often makes the actual split a long way from the point chosen. (due to widely spaced key frames perhaps?)
Is it possible to get MPEG Streamclip to split xvid?
Make a playable file from AVI part 5 when you don't have parts 1-4?
By gumbygum in forum Software PlayingReplies: 3Last Post: 12th Aug 2011, 09:51 -
HELP - Need software for mac that can trim/cut clips without quality loss
By someone04 in forum MacReplies: 6Last Post: 3rd Mar 2011, 19:06 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 18:21 -
what is the easiest software to cut an audio file?
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 14:45 -
Is there a mac program that join parts of a video file in rar pieces?
By VidHunter in forum MacReplies: 5Last Post: 22nd Mar 2008, 08:58
