For those of you who have used DVD-Lab Pro, you know when you open it you go to a screen and it has 3 parts to it and the middle part is where you drag the video up and drop it into the middle part of the screen and that same spot is also where you design it and you can maximize it and make it your full screen...I had no probs doing that on my old computer that I used to use it on, well now I just tried to do it and everything I drag up to that screen only shows half of it and I can't maximize it, I've tried everyway I can and it will no maximize and I need to get it to do that so I can do all the authoring to it that I need to do...I know this sounds confusing ...but if anyone can understand what I meant do you know how I can fix this and why it's doing this?
Results 1 to 12 of 12
Each of the windows in the middle section (which is either the movie, the menu or the connection screen, depending on function) has a maximise, minimise and close control in the top right corner - like an windows app. If you don't have those you either have a serious problem with DLP or windows. Can you please post a screen shot for us ?
Read my blog here.
Here is the screenshot..see what I mean about how the menu part is like, blended in with the rest of it? It's not supposed to be like that, I should be able to take that section by itself and maximize it above the rest if I remember correctly, (it's been since last june since I made a dvd but im almost positive that's how I did it before because I know I never had this problem with this)
no screenshot. Read this https://forum.videohelp.com/viewtopic.php?t=271697
and try againRead my blog here.
I keep trying to shrink the pic and it keeps saying it's too big no matter how small I make it
It's not one set size...I can change it to several different sizes, to where I can drag it from the end..I drug it all the way pretty much from one side to the other & it still said it was too big and there was hardly anything left. The prob. is the menu part of the screen is blended in with the rest of it...where usually it like, sits above the rest to where I can maximize it above everything else, this time it's blended in is the best way I can describe it..I can't do any authoring or anything until I can get it maximized. Any ideas how I can get that maximized? I wish I could get the screenshot up but it's not working no matter what I do
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 21:02 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 31st Dec 2009, 23:01 -
DVD Lab Pro
By matthewjohn23 in forum Authoring (DVD)Replies: 5Last Post: 20th Mar 2009, 12:35 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 09:00 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53
