i've been using AVIMux_GUI for long time.
and after i reinstalled windows for some reason, i cant seem to extract subtitles anymore.
i have ace mega codecs pack professional edition.
what else do i need.
i know theres nothing wrong with the program or the videos cus i'm using the same video files and the same program
Results 1 to 10 of 10
Subtitle should not depend on the codec at all. No error at all? No output either?
bump, sorry i never use bump in forums, but videohelp is the only site that seems to be about videos, lol
You mean that you load an avi, press generate data source and it only shows a video stream? No subtitles, no audio?
first of all, thanks for replying, i really appreciate it.
that test u want me to run sounds like to test the video, like if it has the subtitle stream or not.
and i know the videos do have the subtitle streams because those were the exact same videos that i extracted the subtitles before it stopped working.
so that cant be it.
but tell me what gspot is -
If it helps...
Most video-related software, including AVIMux_GUI, rely on Window's components and various DirectShow filters. If something is missing or broken, AVIMux_GUI probably can't/won't detect or handle the sub stream.
I *think* kschang's question, re: the results of opening the file in GSpot, was really asking for more detailed information about the type of video file you're working with, & what files were used in reading that video, so that suggestions could be made.
Anyway, FWIW & all, audio/video codecs decode the audio/video streams, while the sub portion is demuxed/split, read, displayed using separate filters like the vobsub files. -
Can't see how or why AVIMuxGUI would rely on dshow filters.
The only other app I can think of that would work is Media Player Classic. File-->Save Subtitle.
problem with mkvtoolnix extracting an ssa file, is there another option?
By tetsuwan in forum SubtitleReplies: 0Last Post: 12th Jan 2011, 19:06 -
SSA to SUB
By Abas-Avara in forum SubtitleReplies: 11Last Post: 9th Apr 2010, 07:05 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 20:42 -
ass and ssa to sub/idx
By MasterRoshi in forum SubtitleReplies: 10Last Post: 20th Jan 2008, 16:31 -
MeGui and Avimux_GUI
By voodle in forum Video ConversionReplies: 0Last Post: 17th Jul 2007, 03:48
