I get a lot of files that are 23.97 fps and I want to make DVD with 23.97 fps. But in the output screen, under the standard templates, there is only NTSC and PAL which are 29.97fps and 25fps. 23.97 Is NTSCfilm, isn't it? and there are only NTSC-film templates under VCD and SVCD. How can i make the output in TMPGENC 3.0 Xpress 23.97fps? Can I download a custom template or make my own somehow?
Load the NTSC DVD template and then load the unlock template. This makes all options customizable. So set the output framerate to 23.976fps and enable the 3:2 pulldown while playback option.
If you want to save 2 seconds each time than save this configuration as a new template and use it whenever you want to make a DVD at 23.976fps. -
how do u load the unlock template in XPress? I knew how to do it in older versions, but i cant seem to do it in xpress
like im just trying to make a dvd with 23.976 fps, but its not an option, and i really dont see how u can change that in xpress
It must work, or you can use TMPGEnc PlusLoad the NTSC DVD template and then load the unlock template. This makes all options customizable. So set the output framerate to 23.976fps and enable the 3:2 pulldown while playback option.
Maybe the express version just doesn't have the unlock template in the install package. I know some versions of TMPGenc didn't. You can download the trial version of TMPGenc and copy and paste it from its templates directory to yours.
Or you can easily make your own. Just manually copy all of the settings from your DVD template into a new project, (file/new project) except set it to 23.976fps. Then save it as a new template. -
I think you can, if you output mpeg (not DVD). So, you load NTSC DVD and after that you load mpeg output and change the fps.How can i make the output in TMPGENC 3.0 Xpress 23.97fps?
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 23:12 -
Outputting HDMI signal from laptop to TV
By Gojira in forum Software PlayingReplies: 2Last Post: 1st Jul 2009, 08:32 -
SPDIF not outputting correctly from PC
By bear2616 in forum AudioReplies: 4Last Post: 12th Nov 2008, 17:59 -
Splitting a video in several parts and outputting in one go?
By bigMach™ in forum EditingReplies: 12Last Post: 12th Jul 2008, 21:15 -
Outputting to DVD from 16x9 source
By yadda in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2007, 22:02
