I have some video that I have applied filters to in Virtualdub and I would like to fameserve to TMPGEnc. If I follow the guide(s), will the filters I have applied in VirtualDub be applied to the final TMPGEnc output file? I assume they will be, but I have never really used VirtualDub before. I have looked at a few of the guides but I am a bit fuzzy on how all this works...thanks for any help.
The answer is yes .
I think you add the extension vdr for tmpgenc to open it .
For vdub to bbmpeg :
https://forum.videohelp.com/viewtopic.php?t=270071
(vdub frameserving - avi to mpeg1 or 2) -
A better answer is 'usually'. Not all filters work with frameserving from VD. This from a VD page:
http://www.virtualdub.org/docs_frameserver
Filters that do not work with frameserving:
Any filter that shows a lag value in its description, particularly the "temporal smoother."
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 23:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 13:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 07:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 06:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
