after spending a few hours trying to find the latest drivers for the pinnacle dv500+ card & "bluebox," i had just enough time to do a test capture before i clocked out. as usual, more problems:
the vhs has no protection on it, the content was filmed on a camera and recorded to a tape by a professor. DV capture works fine through the card with the canon camera they have here, but i've changed all the settings and still can't rid the analog capture of these lines.
Results 1 to 9 of 9
Whatever that is, it is definitely NOT interlacing.
Drivers, cable, possible defective card. -
That may be a display driver bug. Try changing the overlay setting of your graphics card.
Looks like either your using bad cable or the connection is faulty.
well, out of frustration, i tried windows movie maker to capture the video
lo and behold, it worked, and has none of those lines. the file format is .wmv. i used a converter program, and converted the .wmv to both .avi and .mpg. the .mpg plays in both windows media player and adobe premier without lines. but when i open the .avi in premier, it has the same lines.
so, it would appear that i have issues with either .avi files or premier. but i (think that i) ruled out the possibility that the problem lies in the cables or the hardware.
edit: i just opened the .avi files that i thought were garbage in VirtualDub, and they play flawlessly. so it appears that the issue lies within premier. i'm going to dig through settings to see if i can find anything.
Truly awful quality VHS - need hints for best cleanup software to =>dvd
By Wills in forum RestorationReplies: 16Last Post: 14th Sep 2013, 15:49 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
VHS capture : red/blue lines
By pastapesto in forum Capturing and VCRReplies: 0Last Post: 24th May 2010, 05:32 -
Converting VHS to XviD - awful quality
By Zippy1970 in forum Video ConversionReplies: 26Last Post: 11th Sep 2008, 09:22 -
Magnetized VHS - How to fix it? (Sample included)
By djnice in forum RestorationReplies: 16Last Post: 18th Sep 2007, 13:14
