Do you know a software that can make a lot wav files fit in Cd, having to reauthor them automatically, with a lower bitrate, when ever necessary?
Couple of questions:
1. When you say CD, do actually mean CD (as opposed to DVD)?
2. Do you mean AudioCD, DataCD (CDROM), or VideoCD?
If, as I'm guessing you mean actual CD, AudioCD. Then NO, you can get 74, 80 or a little bit more (overburning or using CD90's/99's) minutes on disc--And that's it! It's stereo, 16bit, 44100Hz, Uncompressed (LPCM). No other options.
If it's a DataCD, you could compact the wav's into a zip file (or rar, ace, etc) or you could convert to losslessly-compressed format (monkey's, shorten, Apple lossless, etc.) But that's about it (and that'll give you ~double the length of normal LPCM waves). Otherwise, you don't really have a "wav" file anymore, you've got mp3, aac, ac3, etc., and you get compounded loss is you were to re-encode to a still lower bitrate later on.
Please clarify what you really are trying to do.
Scott -
Do you know a tool to convert a "WAV - 6ch - 48kHz" to a "stereo, 16bit, 44100Hz, Uncompressed (LPCM)" ?
You didn't say what bit depth you started with (16, 20, 24 bit?), but I'm guessing 16.
You have 2 main things to do--Downmix (6ch-->2ch) and SampleRate Downconvert (48kHz-->44.1kHz).
Open the 6ch wave(s) in Vegas, Maven3D, or some similar app that fully supports 5.1 audio. Apply steering of the Center,Surround, and LFE channels to what you want in the stereo. Then export (while performing a SRC at the same time).
Or, you could try one of those BeSweet-type processes that does the downmix and downsample. This may allow you to fold the surrounds in with the correct matrixing, so that it conforms to Dolby Surround/ProLogic/PLII. That would retain some sense of "surroundedness". You may want to downsample (SRC) first, before doing the downmix in that case, so that the phase coefficients are more accurate. Of course, some of that would probably get lost if you later decide to have a compressed version. In that case, I would go back to the source and compress a 5.1 ac3, etc. from it.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
I have a lot of .MOD files with the same date, any ideas??
By robisc in forum Video ConversionReplies: 5Last Post: 30th Jun 2011, 08:40 -
how to make a dvd with lot of small video files?
By sumeshkri in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2010, 11:13 -
How to make these Avi files fit to Burn
By jkraze in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 21:24 -
Extracted WAV doesn't fit to original video!
By GangstaRap in forum Video ConversionReplies: 24Last Post: 15th Jan 2008, 20:24
