the video plays for all a few seconds then the screen goes blank,the streaming video is being played on wmp10.ive reduced the video accerleration but didnt change anything.do i need to change framerates?within cam studio.
Check you are using the cam studio codec for the compressor , it dosent like anything else .
Search the forum for video acceleration , or check you hardware video setting's , you should beable to disable directdraw acceleration , and try it again ...
You may have the option to adjust the video acceleration via a slider , bring it back to the left , then try it again .
It's a problem designed into directx9 .
Another trick that might work ... download koolplayer , open a small video and leave it there ... now try wmp10 again ... it seem's to apply direct acceleration to the first player , and not the second .
Although , just thinking of directx9 , I dont see that as a possibilty , they mention two wmp10's running ... this simply dosent work in xp .
capturing with camstudio
By mamo in forum Video Streaming DownloadingReplies: 1Last Post: 7th Aug 2008, 03:45 -
By mamo in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2008, 07:40 -
capturing streaming video
By robotica71 in forum Video Streaming DownloadingReplies: 13Last Post: 14th Mar 2008, 10:18 -
recording/capturing a streaming video
By NateDizzle in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2008, 12:19 -
Streaming Clip Capture Failures w/ CamStudio
By Seeker47 in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2007, 12:27
