Hello,
I have a Hauppauge PVR 150MCE. I know that this card has a hardware mpeg2 encoder. I want to edit my old analog home videos. I have a minidv camera and am using the analog passthru on that to get my video into my computer. After I edit my video I would like to compress to mpeg2 to put onto DVD. Instead of using software compression (i.e. TmpgEnc) is there some way to use the encoder on the Hauppauge to encode?
I thought of feeding my video out to my minidv cam via firewire and then feeding it into the hauppauge card from my camcorder's analog outs.......however I want a more "digital" solution. Is there some sort of software that will encode the Dv files to mpeg2 using the hauppauge chip instead of my processor?
Thanks,
bits
I'll give CCE a shot. Thanks bits.
Just wondering though, in theory the following method should work:
1) edit DV avi files on pc and put them back to DV tape.
2) Run RCA cables from the dv cam into the hauppauge
3) Use capture software to capture mpeg2 from the haupppauge
This method should allow me to convert my DV avi to Mpeg2? Would the loss in quality be too great?
Thanks -
Originally Posted by rahim125
Does the Hauppauge 150 come with DVD authoring software? My USB2 PVR came with uLead DVD Movie Factory, which, IIRC, can take DV as its source.
Just AVOID the RCA/Composite connection with the Hauppauge!!
Use the S-Video connection, this will give much better results.
The composite inputs of the Hauppauge 150/500 are pretty bad.
If you are in for a challenge you can also try output DV from your computer to your camcorder and DIRECTLY capturing the outputted analog video again with your Hauppauge card. 8)
What would be the best free MPEG2 encoder?
By CursedLemon in forum Video ConversionReplies: 12Last Post: 20th Sep 2010, 22:10 -
Recording straight to MPEG2 PAL Video using a Hauppauge HVR-1800
By 3_2_DVD in forum Capturing and VCRReplies: 7Last Post: 22nd Sep 2009, 11:28 -
Which mpeg2 encoder library?
By julesh in forum ProgrammingReplies: 0Last Post: 18th Feb 2008, 15:04 -
DV to MPEG2 using Mpeg encoder
By neftv in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:39 -
best free mpeg2 encoder for me!!!
By malahal in forum Video ConversionReplies: 10Last Post: 9th May 2007, 12:18
