Im looking for a Molex power cable. Its needs to female to female and approx 60cm-100cm in length. Anyone know where I can obtain one from. Im in the UK.
Or a external cable for powering a IDE Hard Drive (Molex).
Ive tried searching and even ebay. Cant find one.
Any suggestions.
Thanks.
Female to female? I don't know where you'd find that, but you might try a splitter, which should have a male connection split out to 2 female connections. Something like this (click here). Then you could use extensions to get the length you want.
What are you trying to do?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
MOLEX is a brand name - but for computer 4 pin -- just make one from some short ones and a piece of wire
or maplin has a kit to make your own (they also have extension cables)
http://www.maplin.co.uk/Module.aspx?TabID=1&DOY=search&ModuleNo=1317&criteria="Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Three Options are available to you:
External USB IDE Adpater w/Molex Power Connector
Follow the advice of Gadgetguy.
or make your own cable. Of all computer cabling(minus networking) the molex power cable is the easiest and cheapest to make. -
Well, I already have an adapter (Abit Serillel2). Its a IDE to SATA adapter so I can use IDE Hard Drives (and optical drives) externally without opening my PC via the SATA port. I already have External SATA connections (via my bracket supplied with my motherboard), but need to power the IDE hard drive. The power cable that came with the adapter is too short and is a male molex connector, but i need female molex connector.
Guess im going to make my own cable. -
Given this description of your project and depending on your experience making your own cables it might be easier for you to buy an adapter such as gadgetguy listed. This would give you the female to female power you need while still leaving the male connection available if necessary. Plus, in my experience you may always find a need for such an adapter outside your current project. Who knows you may even find a friend who needs one down the road and you can sell it them and make your money back.
looking for usb power only cable
By aedipuss in forum ComputerReplies: 8Last Post: 23rd Nov 2011, 12:49 -
Can cable converter box power on with specific channel
By vcd_user in forum Off topicReplies: 2Last Post: 14th Nov 2011, 20:06 -
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21
