i get the following error chrissy when doing a hdtv2dvd job there are 35 .ts files all in but it crashes everytime on file 10.
i have tried file 10 on it's own to no avail probably something to do with the file file in question but who knows
anyway here's the error report m8
btw dogs bollocks software been using it for about 2 years now m8 keep up the good work
Version: SVCD2DVD 2.0
Build: 2.0.2146.38069
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
Can you post your log please?
If you have a ts set which is split like:
Then open a command prompt and change to the directory containing those files. Then do:Code:movie.part0001.ts movie.part0002.ts movie.part0003.ts … movie.part0101.ts
This will join up your split files and give you a big file to use with SVCD2DVD.Code:Copy /B *.ts movies.ts
I think this will give you better results... AND hopefully the error will not happen....
Let me know.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
WOW YOU JUST LEARNED ME AN INVALUABLE WEE TRICK CHEERS AMIGO
ops damned caps in excitement
"attention chrissy boy" Update message shown whilst burning.
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Jul 2010, 12:36 -
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
New Tool: HDTV2DVD
By ChrissyBoy in forum SVCD2DVD & VOB2MPGReplies: 270Last Post: 2nd Jul 2008, 23:05 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59 -
Netframework problem Chrissy
By sc0tsman in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 19th Sep 2007, 18:08
