I use Mac OS 10.3.9 and FFmpegX 0.0.9v
I want to convert a movie file, which is an .avi file, to either SVCD or VCD. the file is about 350 MB and 42 minutes long. I have tried multiple times to convert the file, following the directions at http://homepage.mac.com/major4/divx_svcd.html but all attempts have been unsuccessful. I have read a few threads about people that have had a similar problem but they dont really answer my questions.
Step 1: Opening the source movie .... Done
Step 2: Click the "Quick presets" pulldown menu and choose "SVCD mpeg2enc" .... Done
Step 3: Click the "Encode" button .... Done
The file plays fine in Quicktime but EVERY time the file fails at the end. It says its 100%, but it failed.
My whole goal is to convert to SVCD or VCD and burn it to a CD so I can watch it on my DVD Player
Please Help
PS. I apologize if this has been done before. If so, please direct me to that thread. Thanks.
this is what the log said:
Encoding started on Sun Feb 26 16:18:03 PST 2006
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
movtoy4m
Copyright 2002-2005 Johan Lindstr??m
All rights reserved. Used in ffmpegX under license.
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=352x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 352x480 pixels (253440 bytes)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 352x480, take 352x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 352x480, 352x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 352x480 pixels (253440 bytes)
INFO: [yuvscaler] output: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting SVCD output profile
INFO: [mpeg2enc] Assuming norm NTSC
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.m2v
INFO: [mpeg2enc] Horizontal size: 352 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 2300 KBit/s
INFO: [mpeg2enc] Quality factor: 8 (Quantisation = 9) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 230 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 33 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 60951!
INFO: [mpeg2enc] Signaling last frame = 60950
INFO: [mpeg2enc] Guesstimated final muxed size = 312709055
Computing levels...
lost201manscience --% done, ETA --:--:-- (batch 0% done, ETA 99:14:08)
lost201manscience 1% done, ETA 00:01:39 (batch 1% done, ETA 00:01:39)
lost201manscience 2% done, ETA 00:00:49 (batch 2% done, ETA 00:00:49)
lost201manscience 3% done, ETA 00:00:32 (batch 3% done, ETA 00:00:32)
lost201manscience 4% done, ETA 00:00:24 (batch 4% done, ETA 00:00:24)
lost201manscience 5% done, ETA 00:00:38 (batch 5% done, ETA 00:00:38)
lost201manscience 6% done, ETA 00:00:31 (batch 6% done, ETA 00:00:31)
lost201manscience 7% done, ETA 00:00:27 (batch 7% done, ETA 00:00:27)
lost201manscience 8% done, ETA 00:00:23 (batch 8% done, ETA 00:00:23)
lost201manscience 9% done, ETA 00:00:20 (batch 9% done, ETA 00:00:20)
lost201manscience 10% done, ETA 00:00:27 (batch 10% done, ETA 00:00:27)
lost201manscience 11% done, ETA 00:00:24 (batch 11% done, ETA 00:00:24)
lost201manscience 12% done, ETA 00:00:22 (batch 12% done, ETA 00:00:22)
lost201manscience 13% done, ETA 00:00:20 (batch 13% done, ETA 00:00:20)
lost201manscience 14% done, ETA 00:00:18 (batch 14% done, ETA 00:00:18)
lost201manscience 15% done, ETA 00:00:23 (batch 15% done, ETA 00:00:23)
lost201manscience 16% done, ETA 00:00:21 (batch 16% done, ETA 00:00:21)
lost201manscience 17% done, ETA 00:00:20 (batch 17% done, ETA 00:00:20)
lost201manscience 18% done, ETA 00:00:18 (batch 18% done, ETA 00:00:18)
lost201manscience 19% done, ETA 00:00:21 (batch 19% done, ETA 00:00:21)
lost201manscience 20% done, ETA 00:00:20 (batch 20% done, ETA 00:00:20)
lost201manscience 21% done, ETA 00:00:19 (batch 21% done, ETA 00:00:19)
lost201manscience 22% done, ETA 00:00:18 (batch 22% done, ETA 00:00:18)
lost201manscience 23% done, ETA 00:00:17 (batch 23% done, ETA 00:00:17)
lost201manscience 24% done, ETA 00:00:19 (batch 24% done, ETA 00:00:19)
lost201manscience 25% done, ETA 00:00:18 (batch 25% done, ETA 00:00:18)
lost201manscience 26% done, ETA 00:00:17 (batch 26% done, ETA 00:00:17)
lost201manscience 27% done, ETA 00:00:16 (batch 27% done, ETA 00:00:16)
lost201manscience 28% done, ETA 00:00:15 (batch 28% done, ETA 00:00:15)
lost201manscience 29% done, ETA 00:00:17 (batch 29% done, ETA 00:00:17)
lost201manscience 30% done, ETA 00:00:16 (batch 30% done, ETA 00:00:16)
lost201manscience 31% done, ETA 00:00:16 (batch 31% done, ETA 00:00:16)
lost201manscience 32% done, ETA 00:00:15 (batch 32% done, ETA 00:00:15)
lost201manscience 33% done, ETA 00:00:14 (batch 33% done, ETA 00:00:14)
lost201manscience 34% done, ETA 00:00:16 (batch 34% done, ETA 00:00:16)
lost201manscience 35% done, ETA 00:00:15 (batch 35% done, ETA 00:00:15)
lost201manscience 36% done, ETA 00:00:14 (batch 36% done, ETA 00:00:14)
lost201manscience 37% done, ETA 00:00:14 (batch 37% done, ETA 00:00:14)
lost201manscience 38% done, ETA 00:00:13 (batch 38% done, ETA 00:00:13)
lost201manscience 39% done, ETA 00:00:14 (batch 39% done, ETA 00:00:14)
lost201manscience 40% done, ETA 00:00:13 (batch 40% done, ETA 00:00:13)
lost201manscience 41% done, ETA 00:00:13 (batch 41% done, ETA 00:00:13)
lost201manscience 42% done, ETA 00:00:12 (batch 42% done, ETA 00:00:12)
lost201manscience 43% done, ETA 00:00:12 (batch 43% done, ETA 00:00:12)
lost201manscience 44% done, ETA 00:00:13 (batch 44% done, ETA 00:00:13)
lost201manscience 45% done, ETA 00:00:12 (batch 45% done, ETA 00:00:12)
lost201manscience 46% done, ETA 00:00:12 (batch 46% done, ETA 00:00:12)
lost201manscience 47% done, ETA 00:00:11 (batch 47% done, ETA 00:00:11)
lost201manscience 48% done, ETA 00:00:11 (batch 48% done, ETA 00:00:11)
lost201manscience 49% done, ETA 00:00:11 (batch 49% done, ETA 00:00:11)
lost201manscience 50% done, ETA 00:00:11 (batch 50% done, ETA 00:00:11)
lost201manscience 51% done, ETA 00:00:11 (batch 51% done, ETA 00:00:11)
lost201manscience 52% done, ETA 00:00:10 (batch 52% done, ETA 00:00:10)
lost201manscience 53% done, ETA 00:00:10 (batch 53% done, ETA 00:00:10)
lost201manscience 54% done, ETA 00:00:10 (batch 54% done, ETA 00:00:10)
lost201manscience 55% done, ETA 00:00:10 (batch 55% done, ETA 00:00:10)
lost201manscience 56% done, ETA 00:00:09 (batch 56% done, ETA 00:00:09)
lost201manscience 57% done, ETA 00:00:09 (batch 57% done, ETA 00:00:09)
lost201manscience 58% done, ETA 00:00:09 (batch 58% done, ETA 00:00:09)
lost201manscience 59% done, ETA 00:00:09 (batch 59% done, ETA 00:00:09)
lost201manscience 60% done, ETA 00:00:09 (batch 60% done, ETA 00:00:09)
lost201manscience 61% done, ETA 00:00:08 (batch 61% done, ETA 00:00:08)
lost201manscience 62% done, ETA 00:00:08 (batch 62% done, ETA 00:00:08)
lost201manscience 63% done, ETA 00:00:08 (batch 63% done, ETA 00:00:08)
lost201manscience 64% done, ETA 00:00:08 (batch 64% done, ETA 00:00:08)
lost201manscience 65% done, ETA 00:00:08 (batch 65% done, ETA 00:00:08)
lost201manscience 66% done, ETA 00:00:07 (batch 66% done, ETA 00:00:07)
lost201manscience 67% done, ETA 00:00:07 (batch 67% done, ETA 00:00:07)
lost201manscience 68% done, ETA 00:00:07 (batch 68% done, ETA 00:00:07)
lost201manscience 69% done, ETA 00:00:07 (batch 69% done, ETA 00:00:07)
lost201manscience 70% done, ETA 00:00:06 (batch 70% done, ETA 00:00:06)
lost201manscience 71% done, ETA 00:00:06 (batch 71% done, ETA 00:00:06)
lost201manscience 72% done, ETA 00:00:06 (batch 72% done, ETA 00:00:06)
lost201manscience 73% done, ETA 00:00:06 (batch 73% done, ETA 00:00:06)
lost201manscience 74% done, ETA 00:00:06 (batch 74% done, ETA 00:00:06)
lost201manscience 75% done, ETA 00:00:05 (batch 75% done, ETA 00:00:05)
lost201manscience 76% done, ETA 00:00:05 (batch 76% done, ETA 00:00:05)
lost201manscience 77% done, ETA 00:00:05 (batch 77% done, ETA 00:00:05)
lost201manscience 78% done, ETA 00:00:05 (batch 78% done, ETA 00:00:05)
lost201manscience 79% done, ETA 00:00:04 (batch 79% done, ETA 00:00:04)
lost201manscience 80% done, ETA 00:00:04 (batch 80% done, ETA 00:00:04)
lost201manscience 81% done, ETA 00:00:04 (batch 81% done, ETA 00:00:04)
lost201manscience 82% done, ETA 00:00:04 (batch 82% done, ETA 00:00:04)
lost201manscience 83% done, ETA 00:00:03 (batch 83% done, ETA 00:00:03)
lost201manscience 84% done, ETA 00:00:03 (batch 84% done, ETA 00:00:03)
lost201manscience 85% done, ETA 00:00:03 (batch 85% done, ETA 00:00:03)
lost201manscience 86% done, ETA 00:00:03 (batch 86% done, ETA 00:00:03)
lost201manscience 87% done, ETA 00:00:03 (batch 87% done, ETA 00:00:03)
lost201manscience 88% done, ETA 00:00:02 (batch 88% done, ETA 00:00:02)
lost201manscience 89% done, ETA 00:00:02 (batch 89% done, ETA 00:00:02)
lost201manscience 90% done, ETA 00:00:02 (batch 90% done, ETA 00:00:02)
lost201manscience 91% done, ETA 00:00:02 (batch 91% done, ETA 00:00:02)
lost201manscience 92% done, ETA 00:00:02 (batch 92% done, ETA 00:00:02)
lost201manscience 93% done, ETA 00:00:01 (batch 93% done, ETA 00:00:01)
lost201manscience 94% done, ETA 00:00:01 (batch 94% done, ETA 00:00:01)
lost201manscience 95% done, ETA 00:00:01 (batch 95% done, ETA 00:00:01)
lost201manscience 96% done, ETA 00:00:01 (batch 96% done, ETA 00:00:01)
lost201manscience 97% done, ETA 00:00:01 (batch 97% done, ETA 00:00:01)
lost201manscience 98% done, ETA 00:00:00 (batch 98% done, ETA 00:00:00)
lost201manscience 99% done, ETA 00:00:00 (batch 99% done, ETA 00:00:00)
lost201manscience 100% done, ETA 00:00:00 (batch 100% done, ETA 00:00:00)
Applying adjustment of 0.28dB to /Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.wav...
lost201manscience 1% done, ETA 00:00:00 (batch 1% done, ETA 00:00:00)
lost201manscience 8% done, ETA 00:00:34 (batch 8% done, ETA 00:00:34)
lost201manscience 9% done, ETA 00:00:30 (batch 9% done, ETA 00:00:30)
lost201manscience 10% done, ETA 00:00:36 (batch 10% done, ETA 00:00:36)
lost201manscience 11% done, ETA 00:00:32 (batch 11% done, ETA 00:00:32)
lost201manscience 12% done, ETA 00:00:29 (batch 12% done, ETA 00:00:29)
lost201manscience 13% done, ETA 00:00:33 (batch 13% done, ETA 00:00:33)
lost201manscience 14% done, ETA 00:00:31 (batch 14% done, ETA 00:00:31)
lost201manscience 15% done, ETA 00:00:28 (batch 15% done, ETA 00:00:28)
lost201manscience 16% done, ETA 00:00:31 (batch 16% done, ETA 00:00:31)
lost201manscience 17% done, ETA 00:00:29 (batch 17% done, ETA 00:00:29)
lost201manscience 18% done, ETA 00:00:32 (batch 18% done, ETA 00:00:32)
lost201manscience 19% done, ETA 00:00:30 (batch 19% done, ETA 00:00:30)
lost201manscience 20% done, ETA 00:00:28 (batch 20% done, ETA 00:00:28)
lost201manscience 21% done, ETA 00:00:30 (batch 21% done, ETA 00:00:30)
lost201manscience 22% done, ETA 00:00:28 (batch 22% done, ETA 00:00:28)
lost201manscience 23% done, ETA 00:00:27 (batch 23% done, ETA 00:00:27)
lost201manscience 24% done, ETA 00:00:28 (batch 24% done, ETA 00:00:28)
lost201manscience 25% done, ETA 00:00:27 (batch 25% done, ETA 00:00:27)
lost201manscience 26% done, ETA 00:00:28 (batch 26% done, ETA 00:00:28)
lost201manscience 27% done, ETA 00:00:27 (batch 27% done, ETA 00:00:27)
lost201manscience 28% done, ETA 00:00:26 (batch 28% done, ETA 00:00:26)
lost201manscience 29% done, ETA 00:00:27 (batch 29% done, ETA 00:00:27)
lost201manscience 30% done, ETA 00:00:26 (batch 30% done, ETA 00:00:26)
lost201manscience 31% done, ETA 00:00:27 (batch 31% done, ETA 00:00:27)
lost201manscience 32% done, ETA 00:00:25 (batch 32% done, ETA 00:00:25)
lost201manscience 33% done, ETA 00:00:24 (batch 33% done, ETA 00:00:24)
lost201manscience 34% done, ETA 00:00:25 (batch 34% done, ETA 00:00:25)
lost201manscience 35% done, ETA 00:00:24 (batch 35% done, ETA 00:00:24)
lost201manscience 36% done, ETA 00:00:25 (batch 36% done, ETA 00:00:25)
lost201manscience 37% done, ETA 00:00:24 (batch 37% done, ETA 00:00:24)
lost201manscience 38% done, ETA 00:00:23 (batch 38% done, ETA 00:00:23)
lost201manscience 39% done, ETA 00:00:23 (batch 39% done, ETA 00:00:23)
lost201manscience 40% done, ETA 00:00:22 (batch 40% done, ETA 00:00:22)
lost201manscience 41% done, ETA 00:00:22 (batch 41% done, ETA 00:00:22)
lost201manscience 42% done, ETA 00:00:22 (batch 42% done, ETA 00:00:22)
lost201manscience 43% done, ETA 00:00:21 (batch 43% done, ETA 00:00:21)
lost201manscience 44% done, ETA 00:00:20 (batch 44% done, ETA 00:00:20)
lost201manscience 45% done, ETA 00:00:21 (batch 45% done, ETA 00:00:21)
lost201manscience 46% done, ETA 00:00:20 (batch 46% done, ETA 00:00:20)
lost201manscience 47% done, ETA 00:00:19 (batch 47% done, ETA 00:00:19)
lost201manscience 48% done, ETA 00:00:19 (batch 48% done, ETA 00:00:19)
lost201manscience 49% done, ETA 00:00:19 (batch 49% done, ETA 00:00:19)
lost201manscience 50% done, ETA 00:00:18 (batch 50% done, ETA 00:00:18)
lost201manscience 51% done, ETA 00:00:18 (batch 51% done, ETA 00:00:18)
lost201manscience 52% done, ETA 00:00:18 (batch 52% done, ETA 00:00:18)
lost201manscience 53% done, ETA 00:00:18 (batch 53% done, ETA 00:00:18)
lost201manscience 54% done, ETA 00:00:17 (batch 54% done, ETA 00:00:17)
lost201manscience 55% done, ETA 00:00:16 (batch 55% done, ETA 00:00:16)
lost201manscience 56% done, ETA 00:00:16 (batch 56% done, ETA 00:00:16)
lost201manscience 57% done, ETA 00:00:16 (batch 57% done, ETA 00:00:16)
lost201manscience 58% done, ETA 00:00:15 (batch 58% done, ETA 00:00:15)
lost201manscience 59% done, ETA 00:00:15 (batch 59% done, ETA 00:00:15)
lost201manscience 60% done, ETA 00:00:15 (batch 60% done, ETA 00:00:15)
lost201manscience 61% done, ETA 00:00:14 (batch 61% done, ETA 00:00:14)
lost201manscience 62% done, ETA 00:00:14 (batch 62% done, ETA 00:00:14)
lost201manscience 63% done, ETA 00:00:14 (batch 63% done, ETA 00:00:14)
lost201manscience 64% done, ETA 00:00:13 (batch 64% done, ETA 00:00:13)
lost201manscience 65% done, ETA 00:00:13 (batch 65% done, ETA 00:00:13)
lost201manscience 66% done, ETA 00:00:12 (batch 66% done, ETA 00:00:12)
lost201manscience 67% done, ETA 00:00:12 (batch 67% done, ETA 00:00:12)
lost201manscience 68% done, ETA 00:00:12 (batch 68% done, ETA 00:00:12)
lost201manscience 69% done, ETA 00:00:11 (batch 69% done, ETA 00:00:11)
lost201manscience 70% done, ETA 00:00:11 (batch 70% done, ETA 00:00:11)
lost201manscience 71% done, ETA 00:00:11 (batch 71% done, ETA 00:00:11)
lost201manscience 72% done, ETA 00:00:10 (batch 72% done, ETA 00:00:10)
lost201manscience 73% done, ETA 00:00:10 (batch 73% done, ETA 00:00:10)
lost201manscience 74% done, ETA 00:00:09 (batch 74% done, ETA 00:00:09)
lost201manscience 75% done, ETA 00:00:09 (batch 75% done, ETA 00:00:09)
lost201manscience 76% done, ETA 00:00:09 (batch 76% done, ETA 00:00:09)
lost201manscience 77% done, ETA 00:00:08 (batch 77% done, ETA 00:00:08)
lost201manscience 78% done, ETA 00:00:08 (batch 78% done, ETA 00:00:08)
lost201manscience 79% done, ETA 00:00:08 (batch 79% done, ETA 00:00:08)
lost201manscience 80% done, ETA 00:00:07 (batch 80% done, ETA 00:00:07)
lost201manscience 81% done, ETA 00:00:07 (batch 81% done, ETA 00:00:07)
lost201manscience 82% done, ETA 00:00:07 (batch 82% done, ETA 00:00:07)
lost201manscience 83% done, ETA 00:00:06 (batch 83% done, ETA 00:00:06)
lost201manscience 84% done, ETA 00:00:06 (batch 84% done, ETA 00:00:06)
lost201manscience 85% done, ETA 00:00:05 (batch 85% done, ETA 00:00:05)
lost201manscience 86% done, ETA 00:00:05 (batch 86% done, ETA 00:00:05)
lost201manscience 87% done, ETA 00:00:05 (batch 87% done, ETA 00:00:05)
lost201manscience 88% done, ETA 00:00:04 (batch 88% done, ETA 00:00:04)
lost201manscience 89% done, ETA 00:00:04 (batch 89% done, ETA 00:00:04)
lost201manscience 90% done, ETA 00:00:04 (batch 90% done, ETA 00:00:04)
lost201manscience 91% done, ETA 00:00:03 (batch 91% done, ETA 00:00:03)
lost201manscience 92% done, ETA 00:00:03 (batch 92% done, ETA 00:00:03)
lost201manscience 93% done, ETA 00:00:03 (batch 93% done, ETA 00:00:03)
lost201manscience 94% done, ETA 00:00:02 (batch 94% done, ETA 00:00:02)
lost201manscience 95% done, ETA 00:00:02 (batch 95% done, ETA 00:00:02)
lost201manscience 98% done, ETA 00:00:01 (batch 98% done, ETA 00:00:01)
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX static build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, wav, from '/Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.wav':
Duration: 00:42:22.1, start: 0.000000, bitrate: 1535 kb/s
Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, mp2, to '/Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 619kB time=22.6 bitrate= 224.0kbits/s
size= 1349kB time=49.3 bitrate= 224.0kbits/s
size= 2078kB time=76.0 bitrate= 224.0kbits/s
size= 2808kB time=102.7 bitrate= 224.0kbits/s
size= 3537kB time=129.4 bitrate= 224.0kbits/s
size= 4232kB time=154.8 bitrate= 224.0kbits/s
size= 4961kB time=181.4 bitrate= 224.0kbits/s
size= 5690kB time=208.1 bitrate= 224.0kbits/s
size= 6421kB time=234.8 bitrate= 224.0kbits/s
size= 7151kB time=261.5 bitrate= 224.0kbits/s
size= 7882kB time=288.2 bitrate= 224.0kbits/s
size= 8471kB time=309.8 bitrate= 224.0kbits/s
size= 9208kB time=336.8 bitrate= 224.0kbits/s
size= 9802kB time=358.5 bitrate= 224.0kbits/s
size= 10514kB time=384.5 bitrate= 224.0kbits/s
size= 11242kB time=411.1 bitrate= 224.0kbits/s
size= 11969kB time=437.7 bitrate= 224.0kbits/s
size= 12687kB time=464.0 bitrate= 224.0kbits/s
size= 13397kB time=490.0 bitrate= 224.0kbits/s
size= 14016kB time=512.6 bitrate= 224.0kbits/s
size= 14742kB time=539.1 bitrate= 224.0kbits/s
size= 15467kB time=565.7 bitrate= 224.0kbits/s
size= 16191kB time=592.1 bitrate= 224.0kbits/s
size= 16896kB time=617.9 bitrate= 224.0kbits/s
size= 17614kB time=644.2 bitrate= 224.0kbits/s
size= 18311kB time=669.6 bitrate= 224.0kbits/s
size= 19031kB time=696.0 bitrate= 224.0kbits/s
size= 19745kB time=722.1 bitrate= 224.0kbits/s
size= 20444kB time=747.7 bitrate= 224.0kbits/s
size= 21138kB time=773.0 bitrate= 224.0kbits/s
size= 21580kB time=789.2 bitrate= 224.0kbits/s
size= 21793kB time=797.0 bitrate= 224.0kbits/s
size= 21950kB time=802.7 bitrate= 224.0kbits/s
size= 22491kB time=822.5 bitrate= 224.0kbits/s
size= 23220kB time=849.2 bitrate= 224.0kbits/s
size= 23618kB time=863.8 bitrate= 224.0kbits/s
size= 24340kB time=890.2 bitrate= 224.0kbits/s
size= 25046kB time=916.0 bitrate= 224.0kbits/s
size= 25760kB time=942.1 bitrate= 224.0kbits/s
size= 26408kB time=965.8 bitrate= 224.0kbits/s
size= 27127kB time=992.1 bitrate= 224.0kbits/s
size= 27831kB time=1017.8 bitrate= 224.0kbits/s
size= 28552kB time=1044.2 bitrate= 224.0kbits/s
size= 29277kB time=1070.7 bitrate= 224.0kbits/s
size= 29852kB time=1091.7 bitrate= 224.0kbits/s
size= 30571kB time=1118.0 bitrate= 224.0kbits/s
size= 31285kB time=1144.2 bitrate= 224.0kbits/s
size= 32001kB time=1170.3 bitrate= 224.0kbits/s
size= 32728kB time=1196.9 bitrate= 224.0kbits/s
size= 33452kB time=1223.4 bitrate= 224.0kbits/s
size= 34149kB time=1248.9 bitrate= 224.0kbits/s
size= 34872kB time=1275.3 bitrate= 224.0kbits/s
size= 35602kB time=1302.0 bitrate= 224.0kbits/s
size= 36322kB time=1328.4 bitrate= 224.0kbits/s
size= 37051kB time=1355.0 bitrate= 224.0kbits/s
size= 37763kB time=1381.0 bitrate= 224.0kbits/s
size= 38375kB time=1403.4 bitrate= 224.0kbits/s
size= 39101kB time=1430.0 bitrate= 224.0kbits/s
size= 39826kB time=1456.5 bitrate= 224.0kbits/s
size= 40529kB time=1482.2 bitrate= 224.0kbits/s
size= 41254kB time=1508.7 bitrate= 224.0kbits/s
size= 41980kB time=1535.3 bitrate= 224.0kbits/s
size= 42653kB time=1559.9 bitrate= 224.0kbits/s
size= 43381kB time=1586.5 bitrate= 224.0kbits/s
size= 44093kB time=1612.6 bitrate= 224.0kbits/s
size= 44777kB time=1637.6 bitrate= 224.0kbits/s
size= 45503kB time=1664.1 bitrate= 224.0kbits/s
size= 46221kB time=1690.4 bitrate= 224.0kbits/s
size= 46848kB time=1713.3 bitrate= 224.0kbits/s
size= 47576kB time=1739.9 bitrate= 224.0kbits/s
size= 48299kB time=1766.4 bitrate= 224.0kbits/s
size= 49013kB time=1792.5 bitrate= 224.0kbits/s
size= 49738kB time=1819.0 bitrate= 224.0kbits/s
size= 50237kB time=1837.2 bitrate= 224.0kbits/s
size= 50963kB time=1863.8 bitrate= 224.0kbits/s
size= 51689kB time=1890.3 bitrate= 224.0kbits/s
size= 52415kB time=1916.9 bitrate= 224.0kbits/s
size= 53129kB time=1943.0 bitrate= 224.0kbits/s
size= 53845kB time=1969.2 bitrate= 224.0kbits/s
size= 54397kB time=1989.4 bitrate= 224.0kbits/s
size= 55124kB time=2016.0 bitrate= 224.0kbits/s
size= 55855kB time=2042.7 bitrate= 224.0kbits/s
size= 56570kB time=2068.8 bitrate= 224.0kbits/s
size= 57287kB time=2095.1 bitrate= 224.0kbits/s
size= 58007kB time=2121.4 bitrate= 224.0kbits/s
size= 58639kB time=2144.5 bitrate= 224.0kbits/s
size= 59365kB time=2171.1 bitrate= 224.0kbits/s
size= 60076kB time=2197.1 bitrate= 224.0kbits/s
size= 60802kB time=2223.6 bitrate= 224.0kbits/s
size= 61516kB time=2249.7 bitrate= 224.0kbits/s
size= 62160kB time=2273.3 bitrate= 224.0kbits/s
size= 62864kB time=2299.0 bitrate= 224.0kbits/s
size= 63591kB time=2325.6 bitrate= 224.0kbits/s
size= 64318kB time=2352.2 bitrate= 224.0kbits/s
size= 65044kB time=2378.8 bitrate= 224.0kbits/s
size= 65726kB time=2403.7 bitrate= 224.0kbits/s
size= 66386kB time=2427.8 bitrate= 224.0kbits/s
size= 67111kB time=2454.3 bitrate= 224.0kbits/s
size= 67835kB time=2480.8 bitrate= 224.0kbits/s
size= 68560kB time=2507.3 bitrate= 224.0kbits/s
size= 69273kB time=2533.4 bitrate= 224.0kbits/s
size= 69511kB time=2542.1 bitrate= 224.0kbits/s
video:0kB audio:69511kB global headers:0kB muxing overhead 0.000000%
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting SVCD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 352
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 23.976 frames/sec
INFO: [mplex] Bit rate : 2300000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/Shane/Desktop/FFMPEGX FILES/lost201mansciencemanoffaith.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2568544
INFO: [mplex] Setting best-guess data rate.
INFO: [mplex] Run-in Sectors = 78 Video delay = 50813 Audio delay = 54566
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 60950
INFO: [mplex] STREAM e0 completed @ frame 60950.
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
INFO: [mplex] STREAM c0 completed @ frame 105919.
INFO: [mplex] Multiplex completion at SCR=228830556.
INFO: [mplex] Video e0: buf= 228216 frame=060950 sector=00106343
INFO: [mplex] Audio c0: buf= 736 frame=105919 sector=00031001
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 239621823 bytes
INFO: [mplex] Sequence headers: 4155
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 60950
INFO: [mplex] No. Groups : 4155
INFO: [mplex] No. I Frames : 4155 avg. size 10805 bytes
INFO: [mplex] No. P Frames : 56796 avg. size 3428 bytes
INFO: [mplex] No. B Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 754000 bits/sec
INFO: [mplex] Peak bit-rate : 2538400 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 226106
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 71178244 bytes.
INFO: [mplex] Syncwords : 105921
INFO: [mplex] Frames : 105921 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 67 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
(Super) VideoCD xml description created successfully as `lost201mansciencemanoffaith-1.mpg.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
**ERROR: could not stat() file `lost201mansciencemanoffaith-1.mpg': No such file or directory
++ WARN:
++ WARN:
Encoding completed on Sun Feb 26 17:25:27 PST 2006
1/ The folder name "FFMPEGX FILES" contains a space character, which one of the tools/modules may not like.
2/ Did you check if a good .mpg file was created? If so, maybe only the last part (disc image files) failed, and you can go from here without encoding all over again. Try playback in VLC, mplayer (play button in ffmpegX) and/or QuickTime Player. The latter needs the MPEG-2 playback component to play this file!
3/ If your .mpg file is good, goto Tools, goto Author, select SVCD, and try authoring seperately.
4/ If that works, you'll have Multi-Track CD-ROM XA image files (.img), which you can burn with Toast, as described on the website.
the operation finished this time after i took the space out.
I am using Toast 7.0.1 and it is not letting me drop both .img files into toast.
also those .img files will not mount (i dont know if they need to be)
If you burn with Toast 7, select the "Multi-Track CD-ROM XA" option in the "Copy" tab, which will be available after turning on "Show legacy formats and settings" in Preferences. Click the "Select" button, then drop the two .img files (_01.img first, _02.img second) on the "CD-ROM XA Tracks" window and burn. Repeat for each disk.
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
