I converted the files and now what to edit them. I can't get them to open!
Any suggestions?
You could open them with programs like Womble's MPEG2VCR, or MyFlix XE.
You can also open them with DVD2AVI or Flask. You could use those programs to separate the audio and video, then merge the audio and video with Avisynth to feed to other programs like VirtualDub.
Be warned: if you try to use conventional methods of working with longish MPEG-2 files you will probably run into audio-video sync problems.
I'm trying to convert 60-minute US TV to CD-size using MPEG-1 at 1950kbps. I take the MPEG-2 output by Creative's conversion program, chop out the program parts, extract audio, do an inverse telecine and temporal smoother in Avisynth, merge in Avisynth, feed to Virtualdub where saturation and brightness are increased, then frameserve to TMPGEnc. FINALLY, the files are merged using TMPGEnc.
My next test is to record at a lower bitrate to see if I can avoid a lot of extra work.
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 14:53 -
can't open mpg 2 and flv video files with tmpgeng xpress 4.0
By monks19 in forum Video ConversionReplies: 0Last Post: 8th Oct 2010, 00:53 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
Vegas Pro 8b Cannot Open MPG Files!! HELP :(
By 11233 in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2008, 23:23 -
How to open and play a batch of mpg files in one go ?
By DBenz in forum Software PlayingReplies: 7Last Post: 2nd Sep 2007, 06:22
