    Feb 2006
    I am able to use DVDShrink to copy a movie from a DL to a SL and it works fine. When I try to burn a 1:1 such as from a DL to another DL, the menu items are jacked up, either the link does not align with the menu text or the menu text does not appear at all, but the links for them are there properly. So far the movie works fine, just difficult to navigate without the text. Any ideas? There may have been some other posts on this, but I have not found them as of yet, so if this is true, I apologize.
    Aaron
    Nov 2005
    Well... if you're just doing a copy no need for shrink really. Otherwise possibly reathor or if cutting content from DVD, try other software like VobBlanker?
    Apr 2003
    Maryland
    DVDDecrypter to ISO, DVDDecrypter to burn the resulting ISO works for me. I might run the very latest ANY DVD to defeat any new protection scheme.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
    Feb 2006
    I would really like to do a 1:1 burn to a DL which means keeping all of the original content, but if I need to cut it I will. I actually downloaded VobBlanker yesterday to check it out, but havent messed with it yet, I will try to this weekend.
    As far as removing any protection, I guess Any DVD does this and that you need to run it before you make the ISO?
