Hi, i'm trying to make a complication of a t.v show on a dvd. I used DVD-Lab Pro to author the dvd and made sure the video files were in the right format so my dvd player could play them. The problem is when I try to play the dvd in my player, it doesn't recognize it. I tried DVD + and -. So, i'm wondering if theres a problem with my dvd player or is the dvd's not being authored correctly. Sometimes the dvd's that I burn work and sometimes not.
Results 1 to 10 of 10
There are some important questions.
What format is the video?
What program if any have you used for conversion to the proper format?
What brand of disk are you using? -
and yeah some DVD-players just don't accept DVD-Rs..
check out the DVD-players section here
& what's the player's model no.?? -
The format of the video is SVCD 480x480 NTSC. I used MainConcepts H.264's encoder to convert the video from xivd to svcd and I tried using Fujifilms DVD + R and - R. The dvd player model number is Samsung Progressive Scan Dvd-v3500.
Well that could be one problem. SVCD 480x480 is not a normal DVD Standard. Doesn't mean it WON'T Work but maybe you should try something else?
Some players will support SVCD but many do not. Check your owner's manual for the player. If it supports SVCD, the manual will explicitly say so. If it isn't mentioned, you can be sure that the player doesn't support SVCD.
Ok, thanks for the help. I'll try re-encoding it as DVD format instead of svcd and see of it works then.
Why does Windows7 (but not Xp) have difficulty recognizing my mp3 player
By jimdagys in forum ComputerReplies: 4Last Post: 12th Apr 2012, 11:44 -
Media Player Classic HC not recognizing multiple audio tracks
By DarkLight in forum ComputerReplies: 1Last Post: 31st Mar 2011, 04:50 -
Media Player Classic HC not recognizing both audio tracks
By lordhutt in forum ComputerReplies: 2Last Post: 2nd Apr 2010, 20:04 -
All Drives Not Recognizing Discs
By Celcius in forum DVD & Blu-ray WritersReplies: 7Last Post: 31st Jul 2008, 16:33 -
DVD player doesnt seem to like DL discs..why??
By cduval04 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2007, 03:52
