does anyone know how to extract avi files from a .dat(NOT the vcd type)? it goes like this, in some chinese pc games i have, all the movie files are in a file with a .dat extension that only plays the 1st clip when i try to play it in media player or some other players. however i know the rest of the movies are in the .dat as i have extracted them before using some program, which got deleted accidentally and i dont remember the name of it. can anyone help?
it didnt work, gave an error that says No data, Check my PIDS. thanks anyway
Read my blog here.
A really big guess, check the SCC Tools site: http://www.geocities.com/mcpoodle43/SCC_TOOLS/DOCS/SCC_TOOLS.HTML
for a prog called General Parser & see if that will work? If I remember correctly one of it's original functions was similar to what you want. -
from the instructions on the site, it told me to open CCExtract but i couldnt find it anywhere in the General Parser folder, so i tried using other Project files but none worked. Thanks anyway.
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 08:39 -
Extracting .VRO files???
By jbrdbr111x in forum Video ConversionReplies: 12Last Post: 24th Jun 2009, 20:34 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
