Results 1 to 10 of 10
  1. Since i live in Denmark, and some of my friends are not that good at English, I started to rip my DVD with subs.
    I tried DVDx and Flask.. But it seems like the movie gets a "little" blocky when converted. I usually get much better result with Tmpeg.
    Anyone with a good setting/solution for one of the to programs ?
    Or is there another way to rip a DVD with Subs ??
  2. is it for vcd or svcd???
  3. Well for both....
  4. well you can try DVD2SVCD which you can get selectable Subs only for a standalone and gives great quality and my secon choice is VirtualDub Normal level great quality but long and my thrid choice would be Flask subtitle fix great qualty with PWI plugin and easy and fast one step
  5. Is there any guide for the Flsak solution with PWI ?
  6. yes just foloow the guide on Sefy ulitmat DVDConversion Guide and select the Flask w/ Panasonic Plugin and that is the guide for you
  7. Thx....
    Hopefully - i will get my (s)vcd now with both Subs and Dolby 5.1
  8. You can't do nither VCD or SVCD with Dolby Digital, and Panasonic only supports VCD.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
