how does this sound for a hobbyist just looking to get a new computer since my old shuttle is dying and plans on converting maybe 20 vhs to dvd.
2x160G seagate single layer hdds (so my computer isn't loud)
1g RAM
2006 AIW pci express
plextor 708a
amd something for the processor. not sure yet. any thoughts?
Sounds good for peripheral components but I could add those to just about any machine and call it an upgrade.
The really important matters are in no specific order:
The case construction and setup
The power supply power output and construction
The Motherboard make, model, and supporting ports and connectors
The processor family
The RAM type and amount of pieces
You could buy just about any old hard drive(s), any pci express card, any optical drive, and a single stick of RAM into any case and call it an upgrade. While care should be made when purchasing these components they should be an afterthought once you've picked out your case, powersupply, motherboard, and main CPU(s) you will be using as a base to add these peripherals to. No need to waste money an SATA2 hard drive if your board only support SATA1's. No need to buy 2 sticks of dual channel RAM if your board doesn't support dual channel. You may need to worry about your powersupply being a 24pin if you plan on buying a 24pin board with a PCI-Express card.
You may want to consider case airflow and design layout. A removeable drive cage is nice, but do you want or need it? Do you need a side exhaust? How about a front intake? Is front 1394 important? There are just too many factors to possibly list when you decide to construct your own PC.
A little thought now will save you a ton of "I wish I . . . " later.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
