Umm..not quite sure if this was posted yet but just asking, how do you get a mpg file ready to copy onto a dvd? I have nero 6 and just got avi2dvd software. I just started this video thing so any help would be nice user friendly and budget friendly if possbile (colleage classes suck I'm broke). tahnks in advance.
I'm new to this as well, but I believe you'll need an mpeg encoder to make the mpeg dvd standard. Also, a program to edit if needed. And I wouldn't burn a dvd with Nero (there are plenty of posts about problems with the compatibility of Nero burned dvds. Try either dvd decrypter in Iso write. Or something like copytodvd (has a 14 day full functioning trial version)
What We Do In Life, Echoes In Eternity.... -
First off, get to know what is DVD compliant. If you look to the upper left for 'What is' DVD, that will give you the specifications of the format.
If your MPEG-2 fits into those specs, then all is to do is author it and burn it to DVD. Authoring is the process of creating the DVD disc format, adding menus and chapters. If you are tight on money, there are free encoding and authoring programs available in 'Tools', also to the left.
The most important part of creating a DVD is to educate yourself about the process. There are quite a few guides here available for that. -
It is still better to record (covert) your film correctly. However, if you really have trouble to do so, try Ulead before others. Ulead's software is usually quite forgiving on this.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How do I burn DVD ready .mpg files as a video DVD?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 16:47 -
Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVD
By coody in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Nov 2010, 21:09 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 19:31
