I cut a an Avi into 4 pieces. Then Put it back together by doing the following
Video>Direct Stream Copy
Audio>Direct Stream Copy
File> Open Video File for piece 1
Then File> Append Avi Segment for pieces 2,3, and 4
Then File> Save as AVi
My Problem is that it works fine except when I Play the resulting AVI I see that after clip 4.
Clip 3 and Clip 4 are repeated again. In other words the clips were joined this way. 1234344. So clips 3 and 4 were added 3 more times at the end! Help! I'm using Virtualdub 1.6.1.1
Guess would be that the files are already appended because the checkbox: "Automatically load linked segments" is checked. Then you add them again.
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 15:44 -
joining 2 AVI files via VirtualDub or another program
By cfs6254 in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2008, 12:15 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 20:45 -
Joining AVI videos in virtualDub ?
By Dj-DuDu in forum EditingReplies: 3Last Post: 13th May 2007, 13:31
