Results 1 to 9 of 9
  1. I have some *.vob files.. I can't author them as DVD in Nero - as they will reencode??
    So if I put 'em as data files in DVD (data disc) - will they be playable in my DivX/XviD Hardware player??
    Nov 2002
    No, you'll still need the IFO files to go with it.
    How about extract the MPG from the VOB, then re-author it?
    it depends on the divx/xvid player...try on rw media...you might have to change to .mpg extension.
    but if it's vob just reuthor to a real dvd and it will work.
  4. thanx for all ya ppl's replies..!
    I didn't want to re-author as re-author == re-encode!!
    However, The VOBs play perfectky in my DivX Player- I've tried!
    and yeah then IFOs were also put in the same directory!
    Thanx!
  5. Which divx player are you using ?
  6. Hi-
    Nah, IFOEdit can do it easily. Open it, and in the bottom center hit "Create IFOs". Load your Vob(s) and take it from there.
  7. Which divx player are you using ?
    LG-DS9533 - I'm frm India and it cost me INR 3,350/-
    Hi-
    Oh thanx for the info - I'll try it out..
    So it would'nt re-encode if the IFO is edited??
  8. Of course not.
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    In fact no decent authoring app I know, even can reencode!
    /Mats
