I want to minimize quality loss and processing time, so I'm trying to find out, what are the required file specs (format, resolution, video bitrate, audio bitrate, frame rate, etc.) for a video asset in Ulead DVD Workshop in order for it to be used without re-encoding during the authoring process?
There is no set answer to your question. If you want to capture direct to mpeg2, and not do much editing, then there is no need to reencode. If you want to do lots of editing, then you should capture to avi or dv-avi, then encode and burn afterwards.
Rob -
The file will need to meet dvd spec (see what is dvd to the left) and your dvd template in workshop will need to match the video file.
Google is your Friend -
Some programs also recode files for no apparent reason, even though they are in spec. You should avoid these programs. I'm not sure if Ulead does this or not. Maybe someone else knows.
Wile_E is dead on. Worse, some programs don't allow some things that the specs say are OK. I had an old laserdisc that I recorded to make a DVD. It was a foreign film and at the time it was not available on DVD with English subtitles, but the laserdisc had them. Anyway, one part of my recording had a scene where for some bizarre reason my input card recorded a GOP of 16 frames instead of 15. NTSC DVD allows for GOPs of up to 18 frames. I tried re-recording the same side of the laserdisc and everything I did still gave me one 16 frame GOP. I was using DVDMaestro and it just would not accept the 16 frame GOP at all. I finally just gave up and taught myself how to use Scenarist because it would accept the 16 frame GOP with no problem. I'm not a big fan of Ulead as I had one of their products some years ago as a giveaway and I thought it was garbage. I wouldn't be surprised if they are overly picky about what they accept.
Generally, use standard DVD resolutions, 15 frame GOPs are good, keep the video below 9000 (use 8100 if you are using LPCM audio) for AC3 audio. Generally, the higher your audio bitrate, the better the quality. Warning - many authoring programs will not accept MPEG-1 video input, even though it is allowed by the specs as long as the bit rate is 1700 Kbps or less.
What kind of PC specs do I need to play this MKV file?
By dave in or in forum Media Center PC / MediaCentersReplies: 5Last Post: 22nd Aug 2011, 00:37 -
Computer build questions on motherboard brands and cpu specs- vid encoding
By yoda313 in forum ComputerReplies: 68Last Post: 31st May 2011, 07:55 -
How do you avoid motion lines in your ripped DVD file?
By metrosuperstar in forum DVD RippingReplies: 39Last Post: 18th Sep 2010, 16:04 -
Video Encoding C++ Developer Required
By jsbelanger in forum ProgrammingReplies: 4Last Post: 23rd Mar 2010, 10:53 -
Authoring Information n Help Required
By dbanga in forum Authoring (DVD)Replies: 2Last Post: 30th Jun 2009, 13:13
