How do you make vcds or svcds to play on the xbox?
The first this that most likely needs to be done is to crack the xbox to get it to play backups. Then we can figure out how to get it to play vcds. It shouldn't be too hard since I hear it recognizes the mpeg1 format. U can keep a eye out for news on this on http://www.copyxbox.com . once its cracked and/or vcds are playing on it, it will be in their forums.
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Xbox - JUST DO IT!
By yoda313 in forum Off topicReplies: 4Last Post: 16th May 2009, 00:57 -
video out to tv or xbox
By bballnut in forum Software PlayingReplies: 2Last Post: 25th Apr 2009, 01:29 -
Xbox
By gjordan12198 in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 23:23
