or it means something else? also does xbox 360 play pal?
Results 1 to 17 of 17
there was a dvd that said region : mutltizone, pal, 4:3....what is that suppose to mean?
Do you mean the DVD Region codes?
All region would be a DVD that can play on most any machine in any zone. May or may not be PAL or NTSC. 4:3 is the aspect ratio, same as a regular TV in that case.
Don't know Xbox. -
Well the DVD said
Mutlizone,Pal,4:3...Does that mean it can work on NTSC dvd players also? I live in america, what does multizone mean? -
I'm guessing as they usually call it regions, not zones. A PAL DVD will still not play on a NTSC only player, no matter what region it is. If it's the same thing 'All Zone' would mean it has all the codes on it, basically region free and would play in any zone. Some public domain videos or decryted videos would be region free.
Multi-zone refers to region codes, not format. In your case it clearly says it is a PAL release. All zone may have all regions set, or be set to region 0.
Will it play back in your NTSC player ? Who knows. Your player may play it back, but your TV may not take the signal. You need to read the manual for your player and TV to be sure.Read my blog here.
Lol, i know for sure either my player or tv cant play Pal.
Can i make it ntsc? -
is it a one step process to make it ntsc? also the file is .nrg...
Can somebody tell me how can i convert my .nrg dvd (pal) to NTSC so i can view it on my player?
I saw the guides but im not sure which one fits me the best. Its a .nrg dvd file (pal) and needs to be converted to ntsc to play -
I suspect an .nrg file is a Nero image. You might be able to use something like isobuster to extract the contents to your HDD, otherwise you will have to burn it to DVD then rip it back to the HDD. After than, have a look at the DGPulldown guides. This seems to be the least destruction approach, although I don't believe anyone has come up with a good solution that keeps all your menus etc. intact.
Read my blog here.
Use Daemon Tools (free) to mount the .nrg. Then it's just like a DVD in a DVD ROM/burner- rip it to your hard drive. Extract the mpeg, use TMPGEnc to convert it to an NTSC aspect ration, DGPulldown for the frame rate and reauthor that file to a new DVD.Originally Posted by jesse40902
that means i lose all my menu and stuff? if i did it boks way?
Not if you know what you're doing. Which you don't. Don't run before you can walk. This project isn't for a beginner. You might be better off taking guns1inger's advice and buy a cheap DVD player that can play PAL. -
how much money is that? i live in the u.s....where would i go and how much would i be aiming at? also do they have one that does dual dvd and vhs?
well pop along to a store and see,try walmart or some other cheap store like best buy.
as for the dvd not playing,if it doesnt just rereip it with dvddecrypter to remove the region protection(if it has some),then play it in a cheap player..
american users have a hard time playing PAL discs in there machines,but us PAL users can play NTSC just as easily as PAL.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Wal-Mart usually carries the Philips DVP-642 for $60-70. Amazon.com sells it and also has $40 refurbished ones:
http://www.amazon.com/gp/product/B0009WSB2S/sr=1-2/qid=1140541703/ref=sr_1_2/002-80919...Fencoding=UTF8
It'll play your DivX files also. No VHS.
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
couple "playing Pal in Ntsc" questions
By spiritgumm in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2009, 21:34 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 02:47
