    Sep 2005
    philippines
    i have mkv file,anime.my problem is when convert them to mpeg or vob, the subs are gone. what should i do to retain the sub?
    Dec 2004
    Australia
    Well it sounds like your aim is DVD video, so I would suggest that you demux the subs using mkvextract, then convert to something that your DVD authoring app can handel, author and then burn.
    Sep 2005
    philippines
    yup,thats it! il try it
