I'm building my own machine and I'm looking for an appropriate DVI cable for my GPU to Monitor connection. The monitor I'm getting is a Dell 2405fpw (2407 if it comes out in the next two weeks). I will be using two eVGA 7800GTX KO 256mb GPUs in SLI configuration and I plan on gaming at 1920X1200 resolution. I'm aware that the DVI cable included with the monitor is not dual link and that I will need dual link to get the performance I am looking for. I don't know a lot about DVI cable brands or what to look for and I'm hoping someone out there can point me in the right direction. Thanks in advance!
Try these guys
http://www.ramelectronics.net/html/DVI_dl_cables.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
VGA to DVI-D cable
By ljCharlie in forum DVB / IPTVReplies: 22Last Post: 13th Jan 2010, 14:07 -
DVI/Component cable
By ajcstr in forum DVB / IPTVReplies: 9Last Post: 16th Oct 2008, 06:25 -
Cable to DVI?
By cfgcjm in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 17:25 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 07:49
