Hey guys.
I have had my plasma for about 2 weeks now and during a dvd play (I have not checked during cable, hi def broadcasting yet) I started noticing lines like /\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ that obviously are not black in color but if you look closely you notice them moving while the movie plays. They are horizontal and they are about 2 inches apart from top to bottom and there are a bunch of them.. How can this be fixed?
A regular (non picky) viewer would not notice them but and they happen every time a dvd plays.
I am using regular composite cables and I have always wondered about getting those expensive Monster cables. Are they good? and is my issue related to that?
Use analog component YPbPr cables from the DVD player to TV and try both interlace and progressive modes. The $19 cable set at Wal-Mart will work fine. You can spend more if you wish.
http://www.kiva.org/about
In plasma TV "Number of pixels" and "Number of dots" it's not a same term?
By flash_os in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2011, 13:27 -
New to Plasma/LCD/LED. Should I buy this plasma screen if I'm a gamer?
By Hank Kinsley in forum DVB / IPTVReplies: 4Last Post: 1st Nov 2010, 16:33 -
Problems with "Motion Lines" in SOME ISO to AVI conversions using
By cplevel42 in forum DVD RippingReplies: 8Last Post: 8th Oct 2009, 18:30 -
Toshiba HD DVD player to Dell LCD 17" monitor
By jascman217 in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2009, 22:24 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 23:35
