i'm very new to this, if i have a 150mg avi file and convert it to mpeg and then to a vcd,what is the final size of the file? how many cds would i need for say a 2 hour movie?thanks
What is the time length of the avi file? Whatever time that it is,this is how long the mpeg that you convert will be. If you have an avi file that is 150MB and one that is 600MB - if the length of the clip for both is, say six minutes - then converting them to mpeg, the original file size will not matter.
just like converting mp3's to audio - with VCD whatever file size of mpg you have doesn't matter - because the convertion program looks at the length of the clip. Thats why if you had an mpg of say 800Mb and one of 600MB - looking at them you would only be able to fit one onto a CD (650MB) - as data thats true but as a VCD its not.
So since a 74 min CD holds 74 minutes of MPEG 1(Video-CD) for a two hour movie, you would only need 2 CD's.
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
[Question] How to insert an SRT (Subtitle) file into an AVI file?
By Greg14 in forum SubtitleReplies: 5Last Post: 30th May 2009, 05:54 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Converting AVI file to mpeg 2 question.
By ingeborgdot in forum Video ConversionReplies: 17Last Post: 7th Nov 2008, 21:49 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
