Hey Everyone,
i did something stupid the other day, i didnt read the instructions and plugged in and turned on a USB printer before installing drivers.
Now whenever i am trying to get the printer working it comes up with an unkown device message, even though i have gone through and removed the drivers and started over again its still giving me the um sheets.
its a canon 4200, anyone got any ideas on what is stopping this thing from working?
mic
God created man and finding him not sufficiently alone, gave him a companion to make him feel his solitude more keenly. -- P. Valery
Kind of obvious, but did you unplug the printer, remove any installed drivers? Reboot the computer, install drivers then plug it in?
I usually have the opposite problem. Until I plug my printer in, I can't install a driver.
If you don't get any results, plug it in, go to Control Panel>Device Manager>USB and try 'Scan for Hardware Changes'. If you get nowhere, then uninstall the USB channel and try again. Make sure no other USB devices are plugged in while you do all this. Reboot.
Sometimes XP can get cranky installing drivers. Look around on your printer install disc and see if you can locate the driver. XP wants a .inf file usually.
If you are using XP? No computer info = no useful advice. Or do you have a Mac?
Anyway, that's some of the methods I would try. Not sure how Canon installs.
My HP printer D5360 died, looking for a new DVD printer
By stiltman in forum MediaReplies: 9Last Post: 18th Mar 2011, 23:04 -
WMP11 won't play mpeg2 files after installing Catalyst driver
By jrlouie in forum Software PlayingReplies: 0Last Post: 8th Dec 2009, 21:08 -
Network Attached Storage
By igeekus in forum Media Center PC / MediaCentersReplies: 1Last Post: 31st Aug 2009, 13:58 -
Help PDF printer driver install
By jollyjohn in forum ComputerReplies: 3Last Post: 5th Mar 2009, 08:18 -
Installing a Printer with No Installation Disk?
By The Monkees in forum ComputerReplies: 1Last Post: 10th Mar 2008, 22:38
