For the past two days, I've been trying to import certain clips. These clips are .mov files, and they've imported before and work flawlessly! The error I keep getting is that, as soon as it's about to finish importing it says "Import Failed Due to an Unknown Error". Or something along those particular lines.
These files ALSO play perfectly in Quicktime, so can someone tell me what I need to do to fix this?
Not much info. Is there an error code? What audio and video codecs are you using? How large are the files? The more details, the better your chances of finding a solution.
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 20:05 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
.TOD into iMovie 9 or 11
By 0wa1n in forum MacReplies: 2Last Post: 3rd Jan 2011, 03:43 -
Camileo to imovie
By movietone in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2010, 19:29 -
Using iMovie
By bobl in forum MacReplies: 2Last Post: 2nd May 2008, 20:08
