Ok, so here I am innocently wanting to merge 3 of my video files (wmv). Little do I know ******** want to make my life more shittier.
I open up VirutalDub, throw the first file in it and get this 100% bs error message: “Not support Microsoft own us patent #6,041,345 on the ASF file format” etc (more bs)
How do I fix this?
I think I am going to pirate the next office, next os, and everything else Microsoft because of this BS (that and cause DRM is coming).
Canadans hate DRM!
Results 1 to 11 of 11
Use an older version. This version supports asf...
https://www.videohelp.com/tools?tool=Virtualdub_1.4c-ASF -
asfbin if you just are going to join.
or I think virtualdubmpeg2 supports wmv. -
lol... I already tried both your suggestion....
I already have virtualdubmpeg2 and it did not work.I also tried version 1.3c, Got:Couldn’t locate decompressor for format 'wmv3' (unknown)
edit: as for asfbin, if someone is to lazy to spend time coding up a user friendly screen then they probably didnt spend very long on the program itself.asf: illegal object garment flags 0a etc -
windows movie maker?...it will probably reencode everything though....
yeah l0l... I gave it a try... I am not impressed by the interface but it looks like it work...Originally Posted by Baldrick
tnx... Now I just hope the audio is always in sync.
Microsoft is going down the drain. I should start some Linux propaganda... -
Also ASFTools. Installing ffdshow or WMV9 VCM should solve the VirtualDubMPEG2 error.
You need VirtualDub v1.2, but it doesn't work very well anyway. You'll do better to use something else.
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
