I have a dvdr which has static on the right speaker channel. It's not really stereo, as the audio is identical from each speaker except for the static. How can I recode so it's MONO using the left speaker only (or STEREO and using the left speker for the right)?
extract the audio.
open the audio in goldwave, delete the right track. save mono. convert to ac3 with ffmpeggui. add it back.
see this guide how extract the audio and add it back, https://www.videohelp.com/guides.php?guideid=667&howtoselect=6;57#667
or extract the video and audio with rejig,dvddecrypter, convert the audio with goldwave. and then reauthor the old video and the new audio to a new dvd with any authoring tool. -
Nero's Soundtrax should do it as well, but it's not included in all versions.
Thank you, all.
I tried to demux the audio using Decryptor (as the guides say), but it comes out as an VOB file, not AC3. What am I doing wrong?
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
How to reverse stereo channels for a moive file?
By paytonlow in forum AudioReplies: 7Last Post: 18th Sep 2010, 11:31 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 09:19 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33 -
Removing one of the Stereo channels In Premiere Pro 2.0
By HarveyCee in forum EditingReplies: 7Last Post: 21st Oct 2007, 14:18
