If i have an Audio_TS and Video_TS file set of a movie on my hard disk can i just burn the same like data files onto a blank DVD R or DVD RW and expect it to play in a DVD player without any compatibility of burn issues
If not why not?
Even if you have the file sent on your computer, it is always better to burn your disk using an authoring apps to avoid coasters !
When I was born I was so shocked that I could'nt speak for 18 months. -
If you need something to easly burn a dvd file set to a DVD try imgtools burning tool.
ImgTools
Popular tools to make an image of a DVD Folder(VIDEO_TS) and also burn it. In Addition, the burning tool allows you to confirm and burn a DVD from VIDEO_TS made by any other application. -
or if you use nero, you can just start a new dvd-video project and drag over the files that way...thats how i do mine.........basically, look at it like this, it's kinda like taking an audio cd and ripping it to wav, if you just burn the wav files to the disc without making it an audio cd, the data will still be there, just wont work on most devices, if you make it as an audio cd, it will be a LOT more compatable, same general idea goes here....
How do I burn DVD ready .mpg files as a video DVD?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 16:47 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
Data files into a Video DVD
By galactica in forum MacReplies: 13Last Post: 19th Jun 2009, 09:16 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 02:27 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 04:24
