For tapes that are not very old, is a high end VCR necessary to convert VHS to DVD? I mean if the VCR can play the DVD with good enough quality, is it safe to assume that capturing it to the computer will be just as smooth? It just seems like an awful lot to spend over $100 for a hobbyist looking to convert 10-20 VHS tapes that are in decent condition.
It all depends on what "good enough" means. All tapes have chroma, timebase and grain errors, even commercially produced ones. The severity will range, but it's always there. A high end VCR will lessen or outright remove these sorts of problems. Picking a good capture card or DVD recorder is equally as important.
I agree the cost is a bit much for somebody with only 10-20 tapes, but if those are important tapes, don't half-ass the project. You can always rent, borrow, or buy/re-sell good equipment.Want my help? Ask here! (not via PM!)
For me a high end VCR was a must. I don't do much VHS these days but it is a process where a little noise can downgrade the quality a great deal. What you see on the TV screen is not what you will be capturing in most circumstances. There are decent models out there that are not super expensive these days.
Others have their own views, and there are many that are happy to do a direct VHS copy to standalone desktop DVD recorder. I was never one of them.
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 05:10 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
VCR is NTSC, but VHS is PAL
By joelson in forum MediaReplies: 1Last Post: 2nd Jun 2009, 08:21 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
