I have an BenQ DW400a DVD RW drive which recently stopped burning.... can't do it through XP (professional) or through burning software. Shows up in explorer as "DVD/CD-RW Drive" but when I pull files over it says either to insert a disk (if none is in it) or if a blank disk is in it I get an error that says "J:\not accessible, incorrect function" My NTI burning software just says "no supported drive detected" I can however use it as a regular DVD or CD drive and view files.
I have done the steps below which have not fixed it but I did verify that it is something with my system and not the burner.
Any other ideas of what I might check would be appreciated.
Thanks!
Nancy
STEPS TAKEN ALREADY
Firmware Update: B1LY then tried B1MY
Removed from device manager and rebooted
Checked IDE controller, made sure it was set to DMA and not PIO
Check ASPI Layer. Have 4.6.. tried 4.7 then switched back.
Tested on another system. Worked.
Tested another working burner on this system. Didn’t work.
Nancy Rector
www.cyclopsstudios.com -
Try uninstalling, reinstalling your burning software.
Google is your Friend -
Originally Posted by nanrector
Actually it didnt work through XP when there was no burning software installed.
Also, when you rightmouse click on the drive there is no Record tab.
Could a piece of software have removed that tab?
NancyNancy Rector
There are 2 primary ways to burn in XP. With the built in burning software or with secondary burning software (like Nero for instance).
Since you appear to be trying to use only XP, you can try to do a system restore and find a date before this issue arose. You can boot from your XP cd and perform a repair, possibly it will fix/replace the corrupt file(s). Or you can reinstall the OS from scratch (most likely to work).
Aside from that, you can try to use a secondary program (such as Nero) which works independantly from the XP software.
note: XP actually uses a stripped version of Roxio which is known to have conflicts with other burning software.
Also, there is a registry key which enables/disables the built in burning function.Google is your Friend
my burner stopped burning dl only
By ninjinturdle in forum Authoring (DVD)Replies: 8Last Post: 21st Jun 2011, 13:12 -
Subtitles stopped showing in Media Player Classic
By pzoggy7 in forum SubtitleReplies: 3Last Post: 6th Jan 2010, 12:01 -
[Ask] Checking Video Quality | Media Player Classic Stopped Working
By darkw1zard in forum Software PlayingReplies: 7Last Post: 7th Nov 2009, 14:44 -
Windows Media Player stopped playing .mov files
By dzsoul in forum Software PlayingReplies: 2Last Post: 18th Mar 2009, 23:29 -
Help! Windows Media Encoder stopped working.
By RichardGG in forum DVD RippingReplies: 2Last Post: 6th Feb 2008, 17:42
