I was making a menu with TDA for a dvd (probably made with a dvd recorder) and when I tried to output it, TDA warned that the kbs rate was 10k instead of 9800. I outputted it anyway and burned a copy. Like the original dvd, it plays fine for me.
My 2 questions are:
If I want to give away copies, will all dvd players play this non-standard dvdr?
How do I recode to a lower bit rate?
Results 1 to 14 of 14
If it truly is 10Mbps encoded, then it is DVD non-comlpiant. Some players may not play the DVD and actually, none are required to play it.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
So it sounds that though it worked for me, I should change the kbs rate. Any tool/conversion anyone can lead me to?
your best bet for this, if it really is as high of a bitrate as it appears to be, is to run it through tmpgenc and drop the bitrate some....you can probably get away with like 6000-7000k/s and it will look just fine (i've noted that some commercial dvd's use bitrates like this) or if your intending to give it away only to a few people, take your copy to their house and test it on their dvd player first......that is, of course, if this is a viable option.....
Yes, Nero will certainly recode your video to DVD specs, but many people don't think much of Nero's encoding abilities. At a bit rate as high as yours, hopefully Nero will do an OK job.
Why not just run it through DVDSrhink and compress a bit that way?
Sounds easier then re-encoding the video. -
spiritgumm,
DVD players have buffers to handle small rate spikes that happen in the encoding process. Also as it is on the menu, and thus recorded near the inner edge of the DVD, the read rate is well covered as is the time for second or third error corrrected transfers. Plus it is of short duration. I can't see you having any issues in any player. I'd be even happy to press a master like that. -
Another point, TDA only looks at the decalred maximum bitrate in the header of the file, it does not analyse the actual data rate of the source mpeg. Therefore, chances are the actual data rate is low enough to be DVD compliant. You can use bitrate viewer to check if you want to be certain.
There are 10 kinds of people in this world. Those that understand binary... -
Thank you, all. As TDA has incorrectly often warned that a file was too big for a dvd5, I took the advice to double-check it's bitrate warning. Does a calculator like VideoCalc indicate what it should be, or what it really is? It indicated the bitrate was 9352 kbits/sec (although I don't know what Audio track bitrate I was suppose to use).
Bitrateviewer will tell you the actual bitrate, the free version will do fine.
Errr, yes it does, or how else can it shrink something?Originally Posted by greymalkin
(other than removing unwanted bits)There are 10 kinds of people in this world. Those that understand binary...
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 12:50 -
DVD at high bit rate - Blocky & grainy on big screen
By nharikrishna in forum Authoring (DVD)Replies: 8Last Post: 27th Oct 2010, 03:46 -
avi data rate too high?
By hello2000 in forum Video ConversionReplies: 5Last Post: 3rd Aug 2010, 11:43 -
HD DVD's conversion the high bit rate DVD...can it be done?
By Crankshaft100 in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2008, 18:53 -
best high def televisions for standard definition input?
By EAO in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2008, 15:15
