Hi all,
I'm new here so forgive me for posting about something that's probably been talked about before, but I did search for help.
Basically I am burning VOB files etc onto a DVD-R, I have used Nero and the audio is delayed and out of sync when it comes to playing on my dvd player though on the pc it's fine.
I tried DVD santa and the same thing has happened. I tried using Winavi but it said DVDstruct failed or something.
I don't get what's wrong with it, does anyone have any ideas? thanks in advance for your help.
Results 1 to 9 of 9
Hi Gem & welcome to the forum
Never used DVD Santa, but have read about others having trouble with it.
Give DivXtoDVD a try instead (the 0.5..... version is free). The resulting files can then be converted to an iso using ImgTools Classic (free) and burnt to DVD R/RW using ImgBurn (also free).
Good luck -
Thank you so much for your help and the welcome.
I will download all those and try again.
Fingers crossed.
Thanks again you're a star.
Will let you know.
Kind regards
Gem
Originally Posted by e404pnf -
Hi again,
Just wanted to let you know I used DivXtoDVD and then used ImgTools where it burned the disc and didn't seem to need the ImgBurn program.
Also bought new DVD-RW instead of DVD-R
Guess what? worked a treat, better quality no sound problems and it fast forwards now also.
Thank you very much, I have been struggling with this all for some time.
my friend recommended this site and I'm grateful he did, it's a great forum.
Thanks again
Gem
x
Hi, I certainly will.
I have on more question, do you know how to burn two VOB files onto one disk? they're episodes and I don't really want to do one per disk.
thanks in advance
Gemx
Couple of easy methods...
Without a Menu - If you are starting from several avi's add them sequentially into divxtodvd and it will produce a single VIDEO_TS dir that can be burnt as before. If you already have multiple VIDEO_TS dir's then use DVD Shrink (freeware) in re-author mode (loads of guides to do this).
With a Menu - By far the easiest method is to use TDA. There is a 30 day fully functional free trial if this is a one off project, but isn't that expensive to buy. Again loads of guides to use this programme.
e404pnf -
Hi again,
I'm a bit confused, cos these dvds I burned play fine on my 2 dvd players but not on a friends, could there be any reason for this that's easily fixed?
many thanks all
Gem
x
Occasional Sound issues with a burnt DVD
By Al Slitter in forum Newbie / General discussionsReplies: 28Last Post: 17th Dec 2011, 17:45 -
Video and subtitle/sound sync problems in SubtitleCreator
By ditz in forum SubtitleReplies: 2Last Post: 20th May 2011, 04:12 -
Sound out of sync - possibly GOP problems
By brucexx in forum Video ConversionReplies: 5Last Post: 20th May 2010, 19:38 -
Need to expand sound file to fix sync problems
By Calidore in forum AudioReplies: 0Last Post: 5th Jul 2007, 16:53
