hello
i downloaded an avi that has subtitles in another file called an srt.
can someone plz give me a simple way to just burn the avi to the disc and watch it on a standard home dvd player with subtitles?
i dont mind if the subtitles is stuck there, i simply need a simple solution to watch this movie on the home dvd. ive looked around the net and its seems so complicated.
please help
Results 1 to 11 of 11
easy --
use the " the film machine " to convert the avi and srt file into a dvd with subtitles"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
hi BJ
thanks for helping. could u give me a few steps to follow when using that program please, i downloaded it but have no idea whats going on. i am quite new to this.
cheers -
hey
thanks for the guide, im doing it right now, does it normally take so long for you? my avi file is around 700megs, the first pass took 3 hours and now it's saying the 2nd pass will take 6 hours.
when i burn avis without subitles it never takes that long, am i doing someihng wrong here?
cheers -
Easier to just get a dvd player that plays divx. Then you can write a data disk with your divx files on it & play it, no converting needed. MOst of us have a phillips 642.
seeing your pc system :1,3 ghz??Originally Posted by CoolPerson
it's normally
the only way to reduce the encoding time is in the settings of the filmmachine
to chose for 1 passe and not for a lot of passes
and cce is very faster
it is also 2000$
Add .srt subs to avi movie.
By rogerde in forum SubtitleReplies: 4Last Post: 6th May 2010, 17:57 -
Burn AVI + SRT, but doesn't show up on TV
By waro in forum SubtitleReplies: 3Last Post: 19th May 2009, 11:21 -
How to mux 2 .srt scripts and an .avi movie into 1 container?
By idiffer in forum SubtitleReplies: 7Last Post: 10th Apr 2009, 08:23 -
add/burn srt sub into avi
By volam in forum SubtitleReplies: 2Last Post: 24th Aug 2008, 05:48 -
burn or mux srt with avi files
By greendesert in forum SubtitleReplies: 5Last Post: 3rd Aug 2007, 01:10
