Hi
I have been using SVCD2DVD for sometime with no problems. Recently I have been getting the error below when starting the program. The only way to fix it is to roll back my PC and it's fine for the next convertion but the problem returns on the next use. Any ideas?
It may be nothing to do with it but it seems to have started since I installed Macromedia Dreamweaver?
Version: SVCD2DVD 2.0
Build: 2.0.2070.34697
Type: System.NullReferenceException
Source: Interop.CodeLock
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
mesaboogieman
Perhaps updating to the latest version will help.
Hi ChrissyBoy
Thanks for your reply. I have done just that and so far all is well. I will let you know if it occurs again with the latest version.Time will tell.
mesaboogieman -
Hi Chrissyboy
Getting this error intermittently with latest and previous version. Having read some of the other postings I note one of interest where the person had exactly the same problem and you suggested the following which appeared to solve his problem:
"I have not seen this error before. However, can you try deleting any dnb_xxxx.xml files in the SVCD2DVD folder to see if that resolves the issue? "
I looked at this file and I noticed that on my PC it it associated to MacroMedia Dreamweaver. This is interesting because I have been using SVCD2DVD without any problem for ages and I only installed Dreamweaver about 3 weeks ago which ties in with the start of this problem I think.
Should I change the file association for this xml file type?
Regards
mesaboogieman -
i suspect the xml associations has nothing to do with it.... in fact i removed the dnb_xxxx.xml "concept" altogether....
Can you post the error from the latest build?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi
I'm running the previous version at present. I will install the latest version and report on any errors it gives.
mesaboogieman -
Hi Chrissyboy,
Just for your info I have continued to use the previous version having changed the file association for the xml file to IE and the problem has not occured for 3 days. I have used the PC as normal and run all the programs I had been using when the problem was evident and so far no problem.
Launch program at start up
By CSULB71 in forum ComputerReplies: 4Last Post: 21st Jan 2012, 12:12 -
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 12:52 -
An error x264.exe in MeGUI program
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2009, 14:27 -
MP4 Player - AVIconverter program - Mencoder error
By Fredjklein in forum Video ConversionReplies: 7Last Post: 18th Sep 2008, 22:28 -
Error in Avi2DVD program
By justmenow55 in forum Video ConversionReplies: 2Last Post: 6th Aug 2007, 16:47
