quick question for you pro's out there:
I just copied my first DVD using DVD Decrypter to rip the files, then VOBblanker yo blank out unneeded audio, then DVD shrink to create the burning image; Well when i play my DVD on my computer it looks awesome in widescreen and everything works! However, when I play it in my standalone DVD player, the picture is stretched out to fit the whole screen and the picture looks distorted.
Did i do something wrong? How can i fix it? Why only in my standalone player does it do this?
Thx guys.
VA
sounds like an anamorphic dvd played on a 4:3 tv.
try setting the dvd player to 4:3,or normal tv,or letterbox format.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Skip the VOBblanker step and just Re-Author in Shrink to remove unwanted audio. I always remove everything except the main movie.
thanks guys...a simple adjustment on the DVD player fixed the problem!
VA
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Need help backing up dvd on a mac
By pibrew in forum MacReplies: 1Last Post: 23rd Aug 2011, 16:22 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 09:15 -
Backing up Region 3 DVD
By javajeep in forum DVD RippingReplies: 5Last Post: 28th Jan 2008, 23:55 -
Trouble Backing-Up DVD...
By LCE in forum DVD RippingReplies: 7Last Post: 1st Nov 2007, 00:38
