OK,I have heard about overburning,but this seems to be more than that. I got a disc image of a 90 minute movie (not made by me) which i burned straight to an 80 min CD. The movie is SVCD quality,and is recognized as,and plays as SVCD in my DVD player.
My question is,how can a 90 minute SVCD quality movie be made to fit on an 80 min CD? I thought that an SVCD could hold only about 40 mins![]()
thanks
Results 1 to 9 of 9
Maybe its an xsvcd. They may use the mpeg2 codec but reduce the bitrate to squeeze more video onto it.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Using a bitrate calculator...Audio at 128 kbps, the video would be 1074 kbps to get 90 minutes on a CD. Far too low for SVCD resolution, more like VCD res.
Perhaps it a KSVCD, They seem to be able to fit ridiculous amounts of video on a CD, but with DVD's so cheap it doesn't make any sense to me.
http://www.kvcd.net/portal/index.php"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by culttvguy
Originally Posted by yoda313
Originally Posted by ZippyP. -
Actually, only 480x480/576 is SVCD.
352x480/576 is CVD, a standard that slightly predates SVCD but which SVCD was obliged to be compatible with as CVD compatible players (and discs) had already been released.
I also agree that at SVCD specs, that you are likely to get relatively poor quality video at those bitrates unless you have a particularly MPEG friendly source.
Regards.Michael Tam
w: Morsels of Evidence -
It was a few years ago and I think it was in another forum, but I got into an offline discussion with a guy who was given an SVCD of _Kill Bill Volume 1_ that fit on one CD-R. He gave me a 1 minute sample out of it and it was amazing. The guy who originally made it refused to tell his secrets other than to say that he used VBR under CCE to re-encode it from DVD and he used 20 passes! I examined the video clip I was given and it had some really wild GOP sizes. Nothing was more than 15, but some GOPs were only 8 frames, others might be 10 or 11. The GOP size changed constantly during the clip. I have no idea how to do something like that. The bit rate was all over the place, going as low as 400 Kbps and as high as 2400 or so. The quality was not as good as the original as there were some small artifacts, but it looked a lot better than I thought it should have considering how low the bit rate was and I think most people would find it acceptible. If the GOPs of the disc image the original poster talks about are 15 or less, then it's not KSVCD. KSVCD uses insane GOP sizes like 30 or more frames per GOP. If you drop the bit rate low enough, you can make a standard SVCD and fit 90 minutes of movie on one CD-R, but you'll have to do some fancy encoding (like with CCE) to make it look OK.
I pulled this from the folder called EXTRA on the disc,don't know if anything can be determined from it...
ccefront v1.0 RC3, by Tylo (c) 2005
- 2005-10-26 00:13:13
- WIN_XP
- Input video : 1:33:49 (140731 frames, 25 fps)
- Input ecl file : C:\Documents and Settings\cw_uk\Application Data\CCEFront\work_dir\v001.ecl
- Input avs file : C:\Encodes\F\Video\Fp.avs
- Output mpv file : C:\Encodes\F\Video\Fp.mpv
- Sample percent : 5.0
- Adjust % : 0.0 (accuracy tweak: yes)
- Sizing pass : Encode if opv sz < -0.0%, or > 0.0% oversize, or Q > 40
- Select ranges : every 300, select 15 frames
- Sample frames : 7050
- Using CCE SP version : 2.67.0.27
- Target mpv BR : 1104 (300-9000) kbps, 776835120 bytes
Search for Q:
- Sample encode : Q=32: 951 kbps, err=-13.9%, size=669229123, sample sz=33525416
- Sample encode : Q=25: 1109 kbps, err=0.5%, size=780862781, sample sz=39117768
- Determined Q : 25 = Round(25 + (0.5/2)) with 0.0% adjustment.
- 2005-10-26 01:08:59
- Start movie OPV encoding (Q 25)
- OPV pass result: 101.9% on target (791318192 / 776835120) Speed factor: 0.45
- 2005-10-26 04:37:15
- Start VBR sizing pass (1104 kbps)
- Sizing pass result: 100% on target (776485148 / 776835120) Speed factor: 0.46
- 2005-10-26 08:02:12
- ccefront successfully finished
You can do it (kill bill example) by adjusting the quality under CCE in advanced mode after the 1st pass, and then re-passing, editing again, re-passing etc, tweaking the bitrate distribution manually down to the GOP level, but it takes hours of work to get a near perfect result.
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 00:46 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:20 -
Recommended Min Quality Video settings for CamStudio
By Firewire60 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 07:11 -
Best way to convert a video to iPod with max quality and min filesize
By Salva Veritate in forum Video ConversionReplies: 1Last Post: 4th Jan 2008, 10:34 -
5 hour movie on WMP, 90 min movie on MOVAVI
By jchockey in forum DVD RippingReplies: 0Last Post: 24th Aug 2007, 13:14
